Question about Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Furnace pilot problem
Pilot flame was 8''-12'' high. Replaced orifice. new 1 was approx.1/16'' shorter than the old 1. replaced thermocouple also. Pilot stays lit. When burner flame comes on pilot goes out in2-5min. Sometimes before blower comes on sometimes 2-4 min aft blower comes on. was told the shorter orifice should still work. is that my problem? (when the pilot goes out I hear a click in my control box)
    Problem Solver:
  • 4 Answers
Check the pilot gas pressure, might be too weak and blowing out when the blower starts, the clicking noise is the gas valve shutting down when it detecks no pilot flame, that park is normal.
Posted on Jan 19, 2009
RUDD furnace 90 plus bought in 97 model# ugta 09ezajs Cleaned the flame sensor. Flame would keep kickin on and off run for awhile then just click off completly. Will come back on after reset but do the...
You might have a thermocouple that can't be cleaned. If it looks like this let me know this might be able to help you out.http://homerepair.about.com/od/heatingcoolingrepair/ss/pilot_light.htm If you do have a flame sensor then let me know that also or maybe just write a m# so I can see for myself.
Feb 10, 2011 | Honeywell Power Humidifier: Furnace...
No Water Flow to Honeywell Enviracaire HE225A1006 Humidifier
I have same problem with no water flow on identical humidifier but was able to fix it. Removed the inlet to the solenoid valve and found (1) a small taper mesh filter inside (2) a small diameter orifice that was clogged. Cleaned the miniature filter and used a sewing needle to open the orifice and now works perfectly.
Jan 09, 2010 | Honeywell Humidifiers
Amana furnace main burner intermitent
Sounds like dirty flame sensor. You can either clean it orreplace it.
Apr 21, 2009 | Honeywell Power Humidifier: Furnace...
Water is leaking from the bottom of the unit
The tune up kit that I ordered arrived on Friday and I installed most of it on Friday night. While it is nice to have a new frame and the distribution panel and I think the price of the whole kit was fair considering it comes with the parts and 2 water panels, the fix was really simple.
The kit came with the water distribution tube with with a new blue orifice (Aprilaire #4232) already inserted. This orifice is in the end of the plastic tube at the solenoid end. When I removed the old water distribution tube, the old orifice was not really dark blue anymore but kind of a light blue and was deteriorating from 12 years of exposure to the chemicals in the water. What should have been a pin-hole size opening in the orifice was up to about 2mm or a little more so the orifice was letting way too much water through.
If anyone else has this leaking problem, and your orifice is several years old, I would check that first. It is a $2.75 part and may be the cause of the leak. The whole feed tube kit is only $8.75 and includes the feed tube, nozzle, orifice, ferule, compression nut, strainer so if you need to replace the orifice, I would order the whole feed tube kit for a little bit more.
Hope this helps,
Roger...
Jan 17, 2009 | Aprilaire 700 Humidifier
Furnace blower motor turns on with no flame burning
Hi!!! You might have a bad flame sensor its a single rod located in the burners its white..If the unit runs and then shuts off and on and off.change your flame sensor..Good luckk..
Jan 04, 2009 | Honeywell Power Humidifier: Furnace...
Wall heater does not work!
it sounds like the gas valve is not getting power. There is probably a saftey device that has tripped, preventing the voltage (24v) from energizing the gas valve. check for 24v throughout the circuit. It should be a simple series circuit.
Nov 11, 2008 | Honeywell Power Humidifier: Furnace...
Furnace
I would guess from the info provided that you only have two wires going to your thermostat which would explain why the fan switch doesn't work on the thermostat. You can bypass the thermostat as a first step in troubleshooting. After that it depends on the type of furnace, standing pilot or electronic ignition...
Nov 29, 2007 | Honeywell Power Humidifier: Furnace...
Humidifiers Logo
266 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
