Why is there low output from the Front Speakers of my Sony STR-DE695?
There is good output from the center speaker, sub, and sound speakers, but very little from the Front L/R speakers. I've done the normal Set-up and Levels adjustments. I've tried different speaker wires. I've tried different speakers. I've tried different video sources (BlueRay & DVD). I've tried resetting the system as detailed in the manual. I've tried going to the 2-Channel setting and rifled through all the preset audio settings. No matter what I've tried, the Front speakers are far softer than all the other speakers. Is this an amp breakage or a settings problem?
    Sergeant:
  • 344 Answers
There is blowin out put transisters,
Posted on Nov 29, 2012
easyq
  • 144 Answers
SOURCE: Front speakers no sound!
Most likely you have pressed the speaker AB switch, try pressing it again and see if it works.
Posted on Apr 17, 2009
SOURCE: Low speaker volume for B Side Speakers...
burn radio output
Posted on May 13, 2009
  • 245 Answers
SOURCE: No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
Posted on May 23, 2009
dunnbiker
  • 8546 Answers
SOURCE: Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
Posted on May 21, 2010
Testimonial: "@dunnbiker Very true on assumptions! I've tried everything the manual suggests. Right now, nothing is connected to the unit, but upon power up, I get the SP:OFF display (which is not seen in the DEMO mode). I will try the headphone jiggling idea and see what happens."
dunnbiker
  • 8546 Answers
SOURCE: Sony STR-DH510 Multi-channel AV receiver
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Posted on Aug 06, 2010
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
I have a sony str-DE695 and I am trying to hook up my speakers/record player to it. The record player has an RCA chord with one white and one black end. The speakers has the same chord but with one red and...
the inputs should be marked phone (if on the reciever the colors are red/white and the colors of the rca ends are black white put the black plug in the red and white plug into the white input..if the stereo doesn't have rca speaker output ports you'll need to cut off the speaker rca's and strip the wires bare then comnnect usually copper (red) silver (white) or pos (silver) neg (copper.
Sep 26, 2012 | Sony STR-DE695 Digital Audio/Video Control...
May 23, 2009 | Kenwood VR615 Receiver
Audio out problem
sounds like your sound output ic may have gone.this is normally connected to a heat sink.also check that sound output settings are ok before you go further
Feb 08, 2009 | Sony STR-DB780 Receiver
Hooking up these speakers with STR-DG810 receiver
ya does need a power sub out from a mini unit big sterios have sub pre outs sends signal only u could use speaker but u may blow them i would buy a kilshpsh set best buy 5.1 299 bucks to tie in sterio rock ya aaway
Jan 16, 2008 | Sony DAV-HDX500 System
Patio speakers
connect them to the front left and right outputs.connecting them to the sub-woofer will give poor sound because it only pick's up bass sounds during playback
Oct 29, 2007 | Sony STR-DE575 Receiver
No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Dec 06, 2006 | Sony STR-D665 Receiver
123 people viewed this question
 Grubhead
Grubhead
