How do II put in cable mode - Audio Players & Recorders
    Sergeant:
  • 344 Answers
You don,t
Posted on Nov 29, 2012
Getting 2001 s type out of limp home mode
you should be able to reset it with an OBD II or you can reset by turning engine off , turnng the headlights on and then removing the negative battery cable and the removing the positive cable wait 20 or 30 minutes and then turn headlight switch off and reinstall the cables in reverse of how you took them off!
Jan 30, 2018 | Cars & Trucks
'no signal' inspiron zino 410 hd
Check and reseat ALL cables, swap cables, perhaps the Graphics is bad? Have you tried to boot to safe mode, any change?
Mar 23, 2013 | Dell Inspiron 410 Zino Desktop HD AMD...
I have a Scale Master 2 i want to get it to english standard from the metric that it seems to be stuck at, help
For Scale Master Pro XE Advanced Digital Plan Measure Model 6135 (with PC interface cable Part # 5006).
Switch the Imp/Met Switch to Met
While in Metric mode, MET will remain lit in the display
For Scale Master II v2.0
1)Turn until off via switch
2)Press and hold [SUB] key
3)Turn unti on via switch
4)Release [SUB] key
While in Metric mode, MET will remain lit in the scale box.
Repeat procedure to switch back to Imperial mode.
Sep 23, 2010 | Calculated Industries Scale Master II w/PC...
140Xi II Thermal Printer: how can I put my zebra xi-140 printer in self clea...
There is no such thing as self clean mode. get a cotton swab soaked in 90% or stronger isopropyl alchol and wipe the print head. be careful not to scratch.
May 16, 2010 | Zebra 140Xi II Thermal Printer
How to create my own layouts?
Both the MTX8000 B5 & B7 models are Type II Trunking. If you are (un)lucky enough you might find an F3 modem that does Type II.
If it is an MTX8000 and has a front mounted display with either a 6 button or full keypad, you have a radio that will do Type II.
There were a few B3's that were Type II produced by Motorola. However, you can clone a Type II code plug into a B3 radio and it will work just fine.
You can run system watch using a MTS2000 handheld. Firmware version has to be above 5.44 (which has a 512k controller in it). Most MTS2000/MTX8000's only have a 256k controller, which will not work. You can put the radio into RF modem mode from the F4-F4-F4 (Trunking Config).
NOTE: When the radio is in the RF MODEM mode, it will do a self test and then the screen will go blank. The radio DOES NOT have to be programed to the system you want to watch. You set SYSTEMWATCH to the Spectra with RIB mode (works best). Even watches Type I systems.
If you have the accessory adapter for the side connector on the radio, the typical schematic of the speaker mic looks like this.
If you are using a Public Safety speaker mic with the radio, you might want to order part number 3205514W01 to cover the antenna connector on the radio.
If you are trying to program a MTX-838, from what we've heard, you need to use the MTSX software. The RVN4097F ver R02.10.01 RSS package specifically shows it programs the following radios: MT/MTS2000 MTX838/8000/9000. Now, the update for this software is RVN4097M R06.00.00 05 Sept 97, which should mean that it should program the radio as well. The cable you need is the standard MTSX programming cable.
Do you want to build your own programming cable? If you don't want to use an old speaker mic cable, see the individual part numbers of the parts for the Service Cable, below.
You may want to look at the schematic for the RKN4035D Service Cable. This is the actual Motorola cable used for programming and servicing these radios.
The individual part numbers for the components of this cable are listed below.
jedisvcpt.gif Reference Part Number Description C1 21-84008H06 Capacitor, 33nF 1 09-84538E03 Receptacle, 25pos 2 15-80349B36 Housing, Connector 3 30-05118W01 Cable, 13 Conductor 4 01-80754A26 Plug Assembly 5 42-10217A24 Strap, Tie 6 38-80373B24 Protective Cap 7 04-10058B12 Washer, Nylon 8 42-05184R05 Strain Relief 9 22-05541V01 Pin, Latch 10 41-05538V01 Spring, Latch 11 55-05536V01 Latch 12 15-05691W08 Housing, Connector 13 32-05533V01 Seal, Baseplate 14 32-05472P11 Gasket, "o" Ring 15 64-05241X01 Baseplate 16 39-05895V04 Contact, (13)
Mar 02, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
LG PC Suite II thinks Xenon is only a Music player
You have to go back into settings, others, look under USB connection and change the mode to data (the 3rd option). My phone is in French, so i do not know the exact term, but that will do it. Unplug the USB cable BEFORE you do the change, re-plug the USB cable and that's it! it si no longer greyed out!
Aug 31, 2009 | LG Xenon GR500 Cell Phone
Radio in safe II mode
try disconnecting the battery overnight. that should put it back in safe mode 1.
Jan 09, 2009 | 1995 Audi S6
12 people viewed this question
 Grubhead
Grubhead
