Question about Vehicle Parts & Accessories
I have a crime stopper cool start model cs33 i replaced the battery now the truck starts for a few sec. then shuts off?
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
emo-of-death
  • 9 Answers
SOURCE: remote wont make truck start?
ok this happend to me once take the key and stick it into the ignition and turn it 8 times only turn it untill the lights go on DO NOT START THE ENGINE EACH TIME after this try it again
Posted on Jan 06, 2009
  • 20 Answers
SOURCE: my crime stopper remoye start will not work the
try programing the remote again by going to www.crimestopper.com and to the support tab choosing manuals and manuals again with the model number from the unit under your dash find the manual for that model for any other question you can contact their tech support at 800.998.6880 ext 210
Posted on Feb 09, 2010
  • 20 Answers
SOURCE: crime stopper remote start, panic activates with remote start
try and reprogram the remote buy looking under your dash and getting the model number of the unit then go to www.crimestopper.com and choosing the support tab then choosing manuals and manuals again using the model number from under the dash find yours you can also contact tech support at 800.998.6880 ext 210
  • 20 Answers
SOURCE: found another remote crime stopper
go to www.crimestopper.com but first look under your dash and get the unit number from your actual unit then to the web site choose support then manuals and manuals again and find the number that matches yours if that does not help contact tech support at 800.998.6880 ext 210
  • 132 Answers
SOURCE: crime stopper sp 500 alarm installed in a 2002
30 seconds or minutes. If seconds then the installer taped into the dome light circuit for the door trigger and when the light turns off it's setting off the alarm.
If 30 minutes, I need more info.
Posted on Apr 04, 2010
My husband just purchased a used vehicle 2-5-10, and it came with this crime stopper keyless entry system with remote start. I'm struggling to get our only remote that we received to work. It is a constant...
good day, you may try checking the battery of the remote for it may need a replacement. usually there a small screw attaching it. hope this helps, have a nice day
Feb 10, 2010 | 4-Button Remote Start/Keyless Entry with...
Crime Stopper SP-500 problem
try this web site by crime stopper www.crimestopper.com or you can call their tech support at 800.98.6880 ext 210 you may have to program the remote again. you can also find that at the site by choosing support manuals then manuals again and finding the model number of the actual unit not the remote
Dec 06, 2009 | Combo Alarm and Remote Start with One For...
Crime stopper remote start, panic activates with remote start
Oct 27, 2009 | 4-Button Remote Start/Keyless Entry with...
HOW DOES THE REMOTE OPERATE
Hi There,
Since I don't have your model#, I can't really give you specifics. I realize the model# may not be easily accessible and Crime Stopper markets quite a few different models.
So let's take a different route. Click here for the Crime Stopper tech page. There you can find operating manuals, FAQ's and a whole lot more. Good stuff.
Check accessories for the remotes also.
Best regards
Mike
Oct 19, 2009 | 2-Way Remote Starter
Cool Start model CS34-II TX manual
the problem with this remote is that it is used for a bunch of different models you have to look under the dash and get your unit model number and then check the crime stopper manuals for that units number you do this at www.crimestopper.com under support tab click on manuals and manuals again and then choose the model number you found under your dash
Oct 17, 2009 | 2-Way Remote Starter
My crime stopper remoye start will not work the
Oct 03, 2009 | 2-Way Remote Starter
COOL START REMOTE NEEDS REPROGRAMMING
from http://www.crimestopper.com/techweb/InstructionBooks/RemoteStart/rs1300dp_1304dp_a_ops.pdf Note: All transmitter codes must be learned at time of programming!! The unit will learns up to 4 different transmitter codes. 1. Open Hood (If no hood pin installed with your system, then you must ground the Gray Hood pin wire). 2. Turn key to the ON position. (Pink wire must be connected.) 3. Press Programming button 4 times, then after a few seconds the unit flashes the parking lights 4 times. 4. Press button #1 of the transmitter to be coded. You should get 2 light flashes indicating the unit is waiting for a 2nd code, then press button #1 of a second transmitter, the unit will flash 3 times indicating its waiting for the 3rd code and so on. If all 4 codes are learned, the unit will automatically exit code learning mode, otherwise turn key off and close hood. See diagram below.
Dec 16, 2008 | 2-Way Remote Starter
Vehicle Parts & Accessories Logo
127 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
