Question about Toshiba 14" LCD Monitor
Laptop monitor have vertical lines apearing out of nowhere...
I have a 17in. toshiba satellite laptop and starting 1 month ago there are now 12 vertical lines apearing. There are purple, blue and yellow lines. Can the monitor of a laptop be replace??? Or am I going to loose my laptop???
  • 538 Answers
LCD needs to be replaced.
Common problem called "Tab separation".
Posted on Mar 20, 2009
Vertical lines on laptop monitor
This would need a screen replacement
Lots of people do this themselves
Ebay is a good source for laptop parts most of which are NEW
Aug 26, 2009 | Computers & Internet
Vertical lines on screen
Everything can be fixed.
Try hooking up your laptop to an external monitor. If you get lines then the problem is the video card.
If not, it's the lcd, usually it is anyways.
Just replace the lcd and your problem is gone.
Best of luck!
Feb 25, 2009 | Toshiba Satellite P105-S6207 Laptop
Thin Vertical lines on the screen
Ebay - new screens $110-$135. Google for step-by-step replacement instructions.
Dec 30, 2008 | Toshiba Satellite P30 P35 Series Notebook
Toshiba satellite a105 screen problem
You need a new lcd, The connectors are bad...
Dec 13, 2008 | Toshiba Satellite A105 Notebook
Vertical lines in my laptop screen
This could be a failure in several areas along the path from the video card to the monitor.
Being that there is not an issue across the entire monitor the video card should be considered a last resort check.
Usually this is caused by a loose connection between the LCD driver and the LCD panel itself. Sometimes light pressure applied near the affected line will clear it up. If that does then it is a connection between the LCD panel and the connector to the LCD driver at the panel's edge.
Not much can be done unless you have it repaired by a professional or you can take it apart yourself and apply a pad of some type inside the monitor's edge to apply the needed pressure once assembled.
Aug 11, 2008 | HP Pavilion dv8000t Notebook
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Feb 06, 2008 | Toshiba Satellite P35-S609 Notebook
The LCD would start to fail eventually, there is a fix you can try which has worked for some, but it solely depends if you want to try it out, it might revive your LCD...
http://udpix.free.fr/
Dec 09, 2007 | Toshiba Satellite P30 Notebook
Computers & Internet Logo
483 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
