Question about Onkyo Ht-s5500 7.1-channel Home Theater Speaker/receiver Package
All speakers are humming
New system just bought today, have configured several times
    New Friend:
    Problem Solver:
  • 4 Answers
I have always went straight to the ground wires when a hum occurs in a speaker or speaker system. Are they in phase? Do you have the ground and lead switched?
Posted on Nov 27, 2012
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low...
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Jul 06, 2014 | Kenwood VR-606 Receiver
Woofer and two front speakers work, nothing else.
Did you configure your computer to use theother speakers. Go to control Panel and then Sound and you should be able to configure it there. it also depends on what type of sound card your computer has.
Jun 13, 2009 | Logitech X-530 Computer Speakers
60 HZ hum
Rita's Vintage Audio Repair is a Bob Carver Company & can repairs & updates Subs at a reasonable cost try calling them.
May 05, 2009 | Sunfire True Sub MK II Subwoofer
Constant hum when the computers are connected
Hums come from several sources. A light dimmer switch on the wall. Speakers too close to a monitor or other electrical device. Try turning off everything in the room or nearby rooms, one at a time while the hum is audible.
Apr 15, 2009 | Bose Companion II Computer Speakers
Humming sound (speakers)when HK AVR is powered up.
In my case the buzz was only on front speakers. There are 3 capasitors (100uF/25V) very close to the cooling ribs of 3 regulators in the power supply. In my case the C922 was bad.
Apr 02, 2009 | Harman Kardon AVR 500 Receiver
Sanyo LCD TV speaker hum at low volume
if the hum is only on the speaker s and not the headphones and you have tried the ground and ferrites I would suggest it is a amplifier problem. Either take it back for refund or plug a small set of amplified speakers into the headphone jack. i.e computer speakers or such- that will at least tell you if it is indeed the amplifier.
Feb 27, 2017 | Televison & Video
I just bought new speakers (logitech x-530) which is 5.1. sound only comes out of the front 2 speakers and the sub but not the back 2 and the centre. any ideas? computer specs are: motherboard - asus...
Sorry just doublechecked your board specs. Go to the sound properties in control panel. Click on the configure speakers option. If everything is plugged in right then windows should configure it for you to a 5.1 config. Hope this helps.
Dec 27, 2008 | Logitech X-530 5.1 Channel Speaker System...
Subwoofer humming/buzzing
It sounds like one of the internal solder welds to the cable or a/v connections inside the cable box is bad.
Dec 19, 2008 | Bose Acoustimass 10 III System
Inifinity Entra Sub not working
The hum can be from the power supply not properly filtering, and or the output stage also has a short.
There is the chance that the speaker driver coil is now burned, or the power supply is now dead. If ther output stage is shorted and was putting DC on to the speaker cone, this will burn it very easily.
You should sent the unit out and have it serviced, unless you are properly trained, have the service and engineering manuals, and the test equipment to follow up on a proper repair and calibration.
Jerry G.
Apr 27, 2008 | Infinity PS-10 Subwoofer
Onkyo Ht-s5500 7.1-channel Home Theater Speaker/receiver Package Logo
102 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
