Question about Dryers
What size fuses do you use for the dryer
Model 110 8884490
  • Dryers Master
  • 8,220 Answers
Posted on Nov 27, 2012
Beko condensing dryer Model DRCS68. Hi, my dryer is tripping my electrics as soon as I turn the power on at the fuse spur. Any help on what else could be faulty that is tripping my electrics?
Are your fuses the proper size to run that dryer? A person I know put twenty amp fuses and could not understand why they kept blowing. I am not sure but I think it takes thirty amp fuses.. That's what we put in hers.
Are you sure its wired properly when you replaced the element.
Could be a short some place as well.
Oct 31, 2016 | Dryers
Kenmore elite electric dryer--Model # 110666962501-king size capacity purchased 2007 for a family of two. When I press the start button I hear a faint sound and the dryer will not start.
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Kenmore Elite HE4 Electric Dryer
What size fuse is required. Fuse inside the back cover near where the air comes out blew. Does not say on it what size it is.
its called a thermal fuse readilly available from most any appliance parts outlet either long oval or a button type fuse,take it there with make/model and they will set you up with a new replacement
Mar 06, 2011 | Whirlpool WED5300S Electric Dryer
What size resistor does a kenmore 70 series electric dryer use....?
none that i know of.what is the model number and what is the problem you are having?there are thermostats,thermal fuses element,timer and motor.open the door.look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,just need the model,it will start with 110. or 417.
Jan 30, 2011 | Kenmore 62602 Electric Dryer
My hotpoint tc71 drier blows the plug fuse when switched on what is the problem please
boy the list could be very long but this dyer draws a large amount of current (amps) it should be on its own circuit nothing else on the line at least when the dryer is running you said "fuse" if it is blowing a fuse as opposed to a breaker you could try a Time Delay fuse 15 amps might help please do not put a larger fuse in (even though it fits) the wire size dictates the size of the fuse and increasing fuse size with out changing the wire size to accomodate will create a fire hazzard good luck
Oct 23, 2009 | Hotpoint TDC32 Electric Dryer
In the frigidaire gallery gas dryer where are the fuses
I need to figure out the drum size of my Frigidaire gas dryer with model # fdg8970ew1 and serial # FDG8970E. I need to buy a new dryer and want to make sure I am buying the same size or larger.
Thanks,
Tracy
Jul 27, 2009 | Frigidaire Dryers
Model SE9900 Maytag Stackable Washer/Dryer - 9E Error
According to my data, a 9E error indicates door latch malfunction.
Apr 21, 2017 | Maytag Washing Machines
Kenmore Elite Quiet Pak II front-loading dryer does not heat up
First, check breaker and make sure your fuses are on... Electric dryers run on 220 volts therefore if one breaker is flipped it will turn but not heat.......... if it doesnt solve problem let me know and i will assist futher
Jan 03, 2008 | Kenmore 64902 Electric Dryer
No heat from our REX7648KQ electric dryer.
I couldnt bring up this model # Is it 22ov?full size dryer? I would recheck fuse's should be 2 one for each leg of 110v . I would check to see if you have 220v to back of dryer where the cord mounts to dryer Also some models have themal fuse on burner of dryer in back, this will keep heater from coming on... You can hook the wires together, that hook to themal fuse, being careful not to short wires and test if heater will come on
Sep 16, 2007 | Roper REX4634KQ Electric Dryer
Dryers Logo
Top Dryers Experts
