Question about Jl Audio Car Audio & Video
My jl audio 500/1 makes buzzing noise to subwoofers
When connected the subs makes buzzing noise
SOURCE: jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Posted on Apr 07, 2008
  • 631 Answers
SOURCE: jl audio 500-5
Assuming that you've confirmed that the speaker is in good working order and that the wiring isn't shorted in any way...
There are separate power supplies for the high and low amplifiers. It's possible that the one for the sub output has failed. If that's the case, the output transistors probably failed and that's what damaged the supply.
Generally, I'm willing to help people repair their amps but this is a large, complex amplifier and it should be repaired by a qualified technician.
Posted on Apr 19, 2008
tech48
  • 624 Answers
SOURCE: Can i wire 3 jbl gto1204d subs into 1 jl audio 500/1 amp
You can connect them in a series/parallel configuration. Put two of them in series and then connect the last one in parallel across the two in series. This would give you an impeadance of around 2.7 ohms. Only do this if your amp is stable at 3 ohms or less. I am not familiar with the specs of your amp. If your amp is only 4 ohm stable you can not do this.
This would also give you half the power on the two subs in series as the power for the one that is parallel. The two in series would be sharing the total output signal, where-as the one in parallel would get the entire output signal from the amp.
if you were to connect a fourth sub woofer in this configuration it could give you a 4 ohm load, by adding the fourth sub in series with the single sub that is in parallel. or in other words, yu have two sets of 2 sub woofers each in series. That gives you two 8 ohm loads (two 4 ohm subs in series is 8 ohms). Then you take the two sets of subs and parallel them (two 8 ohm loads in parallel equals 4 ohms).
If i had a picture to show you it would make sense, two subs in series that are in parallel with two subs in series.
Posted on Jun 16, 2008
GooFyTiS24
  • 33 Answers
SOURCE: i bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Posted on Aug 12, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: JL Audio 500/1 Amp
Do you get sound if you set it on full? If you don't get sound in any way it maybe broked. Do you smell burnt components? Is the protection light on? If so you probably have a shorted transistor inside. If everything looks normal but has no sound at all. The preamp circuit is probably not getting power due to a malfuctioning power supply circuit. The way a car amp works is it has a DC-DC converter, which steps up the 12 volts to two supply voltage. One is usually a -35V, an the other is +35V. To a totall of 70V. Power transistors don't operate efficiently on 12 volts thats why it is designed like that. A PWM (pulse width modulation) circuit which consist of a chip, and various components connected to it drives an array of Power FET(field effect transsitors) usually conected in parallel to add power. These FET drive two or more "powder iron core" transformer. The other side of the transformer is connected to large diodes, providing power to the transsistors that actually drive your speakers. The supply voltage to the section preamp section is usually the same as the battery voltage. This preamp section filter high frequency for things such as low pass, high pass etc, and through many stage of amplification using small transistor, the final stage is the large transistors that drive the speakers. If you can tell me more info I can help you with a step by step guide on fixing the amp.
Posted on Jun 28, 2009
How do i wire a 2 speakers to a jl 500/1
I agree with the last answer. I have 1 ten inch sub on my 500/1. it hits great but it would not drive 2 of my Skar wwv dvc subs
Jun 03, 2014 | Jl Audio 12W3 Car Subwoofer
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
Jl 12w3v3 started smoking after hookup
Dang man you roasted it, take it in and get it replaced.Check the gain on the amp try it at 1/3 to 1/2 gain and dont crank up the bass boost all the way try it at like 2/3 that should clean up your sound and cut down distortion-distortion kills subs by heat.
Jan 31, 2010 | Jl Audio 12W3v3-4 Car Subwoofer
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
How do i wire a jl w3 to a jl 500/1 mono
wire the sub in series it will give you best bang
Mar 16, 2009 | Jl Audio 12W3 Car Subwoofer
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
Car audio
mike, this is a beautiful and perfect setup! if you dont have a headunit yet i know the #1 perfect one for you CLARION DRZ-9255 .http://www.clarion.com/us/en/products/2008/audio/source_units/cd/DRZ9255/us-en-product-pf_1172385113235.html i have owned every single piece of equipment that you have! my set up was the same exact way except i used focal utopia 33wx for my subs. but JL AUDIO are the masters at making the best subs for the money by far! i have owned every line of subs JL AUDIO has ever mad,my overall favorite. sean314 623 7054 cell
Sep 11, 2008 | Focal Utopia Audiom 6W Car Mid-Range
How should I wire my 3 subs to the 500/1 amp???????
First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
Mar 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 12w3v4....both smoked and fried on a 500/ jl amp
Unfortunately, it sounds like the voice coils burnt up. There are places that do repair, but for these particular subs, it would be more cost efficient to replace them. I also doubt they are salable, but ebay is a magical place.....
Mar 05, 2008 | Jl Audio 12W3 Car Subwoofer
Jl audio 12w1v2-4
500watts sounds about right to me,i wouldnt go any higher as you risk popping the sub and haveing a melt down in the coil section of the subwoofer.
Feb 18, 2007 | Jl Audio 12W3 Car Subwoofer
Car Audio & Video Logo
35 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Jamie Henning
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
