Question about Onkyo Audio Players & Recorders
Onkyo ht-s5500 speakers are humming
    Sergeant:
  • 344 Answers
They are blowin from turning the system up to loud,
Posted on Nov 27, 2012
ctf1800
  • 4402 Answers
SOURCE: Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Posted on Jan 09, 2008
  • 319 Answers
SOURCE: Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Posted on May 07, 2008
  • 15 Answers
SOURCE: Onkyo ht-r530 Receiver troubleshooting
the 7.1 sound not all the movies has that feature and u need to emulate it, doit in the dolby digital ex and the speakers must sound.
try the volume for the SBL or SBL maybe are to low.
decrease the volume for all the speaker less the SBL, SBR and check it out.
Good Luck
Posted on Jan 12, 2009
SOURCE: onkyo ht-r500 no speakers attached goes directly
I have a HT-R520 - First thing stated in the manual is 'Do Not Apply Power to the System Until All the Speakers Are Connected to the Receiver.' This practice avoids any hot connects to the speakers. As with any high-outpiut system connecting spreaker wires to the system while in operation can spike the speakers as well as the amplifier curcuits. Hook up your speakers first and give it a try. Good Luck!
Posted on Aug 20, 2009
dedlyvirus
  • 11 Answers
SOURCE: I have the Onkyo HT-S5100, the 5 speaker are set
also, you might have to search through the menu of the receiver, and set the surround back speakers to be zone 2 instead of using the 7.1 configuration that is probably default.
i think zone 2 will only play sources that are hooked up with analog connects, ie. red/white cables. try using the radio to see if it works. you might have to hook up your cable/sat box, cd player, dvd player, whatever you have that you want to listen to with both digital and analog cables to get everything to work right.
Posted on Oct 16, 2011
Onkyo HT-R693 (HT-S7700) receiver will play video but no audio on Netflix and YouTube. However, sound comes through when connected to Comcast cable and even Pandora. I have tried the different channels...
  • Check your cable connections
  • set the input selector to the proper component sources your using.
  • set your speaker settings to either 5.1 or 7.1, according to your speaker configuration via Onkyo's AccuEQ automatic setup tool- because the same binding posts can be used for hooking up the Atmos height or surround back speakers; you'll need to tell the Onkyo system which setup you're using.
Mar 08, 2015 | Onkyo Audio Players & Recorders
Onkyo HT-R510 left side speaker garbled
Out put transister could be fried ,Or the speaker is blowin,
Nov 29, 2012 | Onkyo Ht-r510 600w 6.1 Dts Home Theatre...
All speakers are humming
I have always went straight to the ground wires when a hum occurs in a speaker or speaker system. Are they in phase? Do you have the ground and lead switched?
Nov 27, 2012 | Onkyo Ht-s5500 7.1-channel Home Theater...
I have a Onkyo Model HT-S5300 I can to install two additional front speaker I want to know the speaker specification that i can install
The speakers and amp are optimized at 6-ohms. Adding speakers will require you to run them in parallel with a possible dangerously low impedance; or in series, doubling the impedance which is safer.
These products are not designed to be modified.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/search?q=Onkyo+Model+HT-S5300
Specs page 58-59.
Apr 24, 2011 | Onkyo HT-S5300 Theater System
Does onkyo HT-s3100 supports 4 Ohms speakers from JBL(control 1)
Palaboy is incorrect. JBL Control 1 speakers are 4 Ohm 150 watt speakers. He's probably thinking of the Control 1x speakers which are 8 ohm 80 watt speakers.
If you hook your Control 1s to that Onkyo, it won't sound great and could cause the receiver to overheat and trip the protection circuit if played at high volume.
Aug 11, 2009 | Onkyo HT-S3100 Receiver
Onkyo ht-s5100 lost sound
Double check that the approtiate speakers (A or B ) are selected.
Jul 10, 2009 | Onkyo HT-S5100 Theater System
It's possible that you have the wrong speaker set (A or B). Look for that button and change the setting and see if that works
Mar 25, 2009 | Onkyo HT-S5100 Theater System
Apr 22, 2008 | Onkyo TX-SR605 Receiver
Onkyo HT-R520
Hello the HT-R520 is the model of the receiver that is part of the HT-S770 package. I suggest that you check the speaker settings. Check the level of the center speaker. If you need assistance please contact Onkyo at 800-229-1687 option #3. Thank you, Onkyo USA
Jul 02, 2017 | Onkyo HT-SR700 System
Onkyo HT- S790 installation manual
You can find manuals for Onkyo products here http://www.onkyousa.com/download/own_manuals.cfm
Jul 22, 2007 | Onkyo HT-S790 Home Theater System System
50 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
