Question about Health & Beauty
Invacare Nutron r51 Service Manual - Health & Beauty
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 104 Answers
Must be certified by mfg to get one but you might get lucky on craigs list
Posted on Dec 18, 2012
What do eight wrench flashes indicate?
hi. according to Invacare,, the following joystick is used with the wheelchair you mention...
https://www.invacare.com/product_files/1110532.pdf
goto page 33 for more detailed help
Please let me know how you get on ..
regards
Rob
Dec 23, 2015 | Invacare Nutron R51LXP
My invacare nutron r51lxp doesn't do anything when I push the power button. I know for certain my charger works
hi , it could be something silly like a fuse , hopefully it is otherwise it sound like a joystick controller issue ?
Check the battery fuses and reset fuses if any are fitted .
Regards
Rob
Aug 09, 2015 | Invacare Nutron R51LXP
Why joystick operate opposite
Sounds like the power connections were hooked up backwards. Swap the + and - connections and it should correct the problem
Jul 04, 2015 | Invacare Nutron R51
How would tilting the chair cause it to stop operating?
Look for safety features when chair tilted, damaged safety inclination limit
May 28, 2014 | Invacare Nutron R51
Nutron r51
The age of the Nutron is not the issue, unfortunately. I have seen problems with this model right out of the box. The joystick control is the first area to check. If you have to compensate the joystick so far to the right to correct, you may have a damaged joystick gimbal. You may also have a bad joystick control board or damaged connecting cable to the controller on the bottom frame. Check for damaged, pinched loose or disconnected wiring below at the controller module. With a folding frame it is easy for the wiring to be become damaged or dislodged. Check for cut damaged pinched wiring at the joystick. With a handheld programmer (dealer) you can check for error codes in the fault log. With a poor performance issue there may not be a fault recorded in the log of the computer module. I have also seen these motors fail prematurely. In this case your left motor is dragging or weak causing the chair to go left. With a programmer (dealer tool) you can compensate for this while waiting for new parts(temp fix). Sometimes the motor brushes burn or hang up. Try blocking up the chair off the ground and run it no load to check for motor performance and unusual sounds. Check for joystick dead spots or uneven action. A quick check of the joystick would be to plug in a known good one at the dealer to test. With the chair blocked up try tapping the motor housing to see if the performance changes. Inspect the brushes if you have access to the brush caps.Check the obvious first, plugs, pinched, broken wires and partial plug disconnects and corrosion. If you have a voltmeter you can do some checks on the motors and brakes. Going from memory, the motor leads large black and large red should read zero ohms with the 2 small white wires for the brake reading between 60 and 70 ohms. Check the Invacare manufacturer website for exact specs and technical info for this model.
Hope this helps.
Mar 22, 2014 | Invacare Supply Group Nutron R51 LXP...
When I turn my wheel chair on sometimes it won't run at all and the light flashes red, green and orange and it won't move. other times it can me moving pretty normal and then all of the sudden it will...
hello visit: www.alldatasheet.com and download- troubleshooting_2007 SHOPRIDER.pdf AS A PDF FILE SAVE IT TO YOUR ADOBE READER,ANY PROBLEMS ASK AGAIN PLEASE ,HAVE A NICE DAY COLIN.
Dec 01, 2010 | Invacare Nutron R51 Folding Power...
The light blinks red 1 2 3 green
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Nov 04, 2010 | Invacare Nutron R51 Folding Power...
My question is related to an Invacare-Nutron R51.Production date 1-7-03,joystick[MKIV R11] flashes red 1 time, than green 5 times repeatedly? Can you please tell me what this means.?
Ranch well the red flash indicates a low battery and the 5 flashes indicate a bad left brake. Now try charging the batteries until you get a green light on your charger then turn on the chair it shouldn't flash the red if the batteries are accepting the charge. If your batteries are 2-3 years old it could be time to change them. If Medicare paid for your chair then they will pay most of the repair costs. You can contact your provider for help or a service company like Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733. If Medicare did buy the chair then you are eligible for a new chair every 5 years and yours is almost 8 years old. Contact a local provider that you trust to check into getting you a new chair. Hope this helps you
Sep 29, 2010 | Invacare Pronto M51 Power Wheelchair
Not charging
The batteries need to be replaced. When the chair sits for a while without being charged, the batteries wear down to a point that they cannot be charged.
Dec 08, 2009 | Invacare Nutron R51 Folding Power...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
