Question about LG LBN22515 Bottom Freezer Refrigerator
Loud Motor Within the last hour, the motor has become noticeably louder. It is coming from the middle of the fridge- I think. Excessive vibration from the motor. When I open the door the motor stops and when I close it starts up again.
    New Friend:
I had the same issue. On the hottest day of the summer I simply took the entire bottom freezer shelf out, frozen items and all, the secondary tray and then removed the one screw from the back panel. The panel does not come far away because of the electrical connections, but I did expose the central fan with connections in place. I could only see small amounts of ice but after 3 minutes of a hair dryer on that fan, two larger chunks of ice fell out and the problem was solved.
Posted on Aug 20, 2015
    Genius:
  • 1,198 Answers
It's probably the circulator fan. It will be inside the fridge or freezer, behind a protector. You'll have to remove all the stuff in front of it, shelves, etc, to get at it. Something has fallen into it, or it has ice nearby. You may have to do a manual defrost. If you find lots of ice, your defrost system has a problem. Locate your defrost timer and mark the little movable part on it with white-out to see if it moves. It should take an hour to see any change. It should hum if it's working.
Posted on Jan 10, 2009
My washer is getting louder and louder
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Mar 23, 2015 | Kenmore Oasis HE 27082 Top Load Washer
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
Sep 16, 2013 | Refrigerators
Frigidare freezer making buzzing sound like a motor
You hear the evaporator fan that is probably rubbing on some ice buildup. Remove the rear panel in the freezer to confirm that there is ice buildup and post back to me.
Nov 17, 2012 | Frigidaire FRS23KF7AB Side by Side...
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
After investigating on line I realized my Admiral (model LNC6760B71) had a worn out snubber. It ran shaking for awhile before I found time to diagnose it. I ordered the snubber and a week ago took it apart...
It sounds like you may have a bad bearing that was caused by the basket that was moving around excessively. But, this wouldn't cause a 'no power' situation. If you can still hear the motor turning, then you likely have broken the drive coupler between the motor and the transmission (fairly common, made of plastic!). If you cannot hear the motor, then troubleshoot for a stuck 'out of balance' switch, it will be located near the top of the basket near the rim somewhere. It may require replacement, but due to the excessive vibration, I suspect it may just be a wire that has come off. The sound that you heard is explained by a bad bearing / broken coupler. But the power issue isn't.
Feb 13, 2011 | Maytag Washing Machines
Very loud noise and the middle bit between the fridge and freezer isvery hot to touch with my powepiont model no TRF295 what shall i do?
loud noise comes from moving parts such condensor fan motor, evaparator fan motor. be sure they are nt hitting shroud. other is compressor-may be going bad. heat in middle is coming from mullion heater,as long as it doesnt melt gasket or short out, trip breaker should be ok.
Aug 26, 2009 | Refrigerators
8 year old Whirlpool gas dryer will not run - it just hums when put on any setting. Is this a motor problem or the belt?
it sounds like the motor....generally before the motor dies the motor will become louder and louder, and when its hot and you try to restart it it will make a loud hum as it tries to turn
Dec 31, 2008 | Dryers
Loud intermittent vibration in 1997 Toyota Land Cruiser
100 series landcruiser auto 98 model 226000 km
whine from front end after 25 kmh no noise when backing off
Nov 23, 2008 | 1997 Toyota Land Cruiser
Vibrating noise from freezer/fridge?
take the cover off the fan in the freezer section and see if the fan blade is loose or hitting ice the blade just pushes on make sure the mountings are tight its probably the blade but you might need to replace the motor if i reamber correctly on the cover there is a screw at the bottom you remove then slide the cover up and its on hooks plastic hooks built on the cover ok
Mar 28, 2008 | Refrigerators
LG LBN22515 Bottom Freezer Refrigerator Logo
247 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
