Question about Kitchen Ranges
Hi I have an older magic chef electric range that while the oven was on it all just shut down. The range is getting electricity to it because the panel lights will come on if I turn a burner on, however it does not heat either the oven or a burner, help?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number?
Posted on Nov 27, 2012
battlesmith
  • 382 Answers
SOURCE: lighting pilot light on magic chef gas range
Hello Jim,
Try to replace the ignitor if it is more than 3 or 4 yrs. old..If it not that old then Turn the knob to the pilot setting and depress the handle. Holding it down and at the same time, press down on the red button that sparks. You may have to repeat this a few times. Once the pilot lights, continue to hold down on the pilot knob for about 30 seconds. When you release the knob, the flame should stay oN. If it does not, replace the thermocouple. Once the pilot flame is steady, turn the gas valve knob to on!!!..Thank you...
Hope this helps you!!...
Regards!!!....
Posted on Jul 24, 2008
docjohn174
  • 943 Answers
SOURCE: Electrical problem w/ magic chef electric range CER3540AAA
hi thanks for the question i would check to see if theres 240 volts at the stove if only 110 volts at stove you will not get any heat but lights will work check that replace fuses in main panel for the stove thanks the appliance doc
Posted on Sep 27, 2008
  • 1214 Answers
SOURCE: magic chef electric fee standing range model 35ja-26x
Sounds like a shorted element. This can happen if the element shorts to ground near the middle of the element. Current will then flow from the unswitched side of 240 VAC to nuetral or ground, heating up the same as if on 240 VAC.
Posted on Jan 24, 2009
fixyourboard
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
  • 119 Answers
SOURCE: Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Posted on Feb 14, 2010
I set my magic chef oven at 400 degrees,and it shuts off before it reaches the temp.
Have you checked the internal temp with an oven thermometer?
The thermostat might need calibrating or replacing, or, (if electric) the oven might be seeing an "overload" condition and shutting off.
Dec 12, 2016 | Magic Chef Kitchen Ranges
After oven cleaning F2 appears and I can not open door on old Magic Chef electric range?
Hi charleybead,
F2 error appears when the Oven temperature is too hot. Please check the sensor harness. Replace relay board, if present, or oven temperature sensor (RTD).
Hope it helps.
Thank you for using FixYa.
Sep 01, 2011 | Magic Chef 31000 Gas Kitchen Range
Our oven turns on for a few minutes but then shuts off before it even pre heats...? can you help
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 26, 2010 | Magic Chef Kitchen Ranges
My oven will not stop beeping F 1. It's a Magic Chef wall oven. Electric
Hi
Thanks for using FixYa. Error code F1 means failed thermistor/transistor in control. To resolve this issue you'll have to replace the Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Magic Chef 9815 Electric Single Oven
How do I use the self cleaning on my Magic Chef conventional oven
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Sep 06, 2010 | Magic Chef CER3725AA Electric Kitchen...
F3 error on magic chef electrical range
Hi glrecu,
The F3 fault code description is a shorted or open oven temperature sensor (RTD). Please check the sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope it helps.
Sep 06, 2009 | Magic Chef 31000 Gas Kitchen Range
I can't get my oven to go on, keep getting f-7 code on panel
F7
Function key shorted or stuck button Clean and un-stick button or replace Touch Pad or Clock
Apr 11, 2009 | Magic Chef CER3760 Electric Kitchen Range
Magic chef electric fee standing range model 35ja-26x
Jan 24, 2009 | Magic Chef CER3740 Electric Kitchen Range
Broken glass top on Magic Chef range
all i want to know is how to turn on the self cleaning oven to clean it. i can't remember and i can't find the book
Jul 25, 2008 | Magic Chef CER3740 Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
