Question about Maytag Washing Machines
Washer overflow from drain pipe
Just got washer today 3 yrs old looks like new hooked up started load when draining overflowed out drain pipe seems like too much water or too fast thanks
    Sergeant:
  • 198 Answers
If the water continues when electricity is discontinued the soleoid valve is jammed open, a fleck of rust or something, not designed to be repaired, it is easier and cheaper to replace. they are a standard part that fits 99% of all washers ~$10-20 at the local parts guy.
Usually only the cold solenoid has failed. it gets used more often.
If you are like me and only use cold water, swap the hoses on the taps, and swap the wire connectors on the solenoid valves, so the former hot is now cold, and you will get about the same number of years before you have to replace anything
Posted on Nov 27, 2012
SOURCE: Water overflows from drain pipe
on the drain go down 6 inches ,add one 90elbow,extend up to the height of the original drain.should relieve the air that is pushing the water out.
Posted on Sep 13, 2008
  • 351 Answers
SOURCE: my washer drain pipe overflows when draining. i've
no you have a drain problem .... i would recommend calling a plumber the only thing it could be is drain problem there is no such thing as draining to fast.
Posted on Apr 30, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: drain pipe overflows from washer
Something is blocking the drain and it can't keep up with the flow now. You can try cleaning the drain with an auger (available for not much money at home supply stores). You'll probably find a sock or lots of lint built up.
Posted on May 13, 2009
barkencoa
  • 3463 Answers
SOURCE: the water drains too fast and overflows
Any washer cannot drain too fast, the problem is in your drainage pipework, there is likely to be a partial blockage or restriction of some kind, it means rodding the pies, or taking it apart to clean it.
Posted on Mar 24, 2010
heatman101
  • 43501 Answers
Here is a tip that will help you with that problem...
Changing or Upgrading your Old Washing Machine
http://www.fixya.com/support/r4696582-changing_or_upgrading_old_washing_machin
heatman101
Posted on May 17, 2010
The water drains too fast and overflows
heatman101
May 14, 2010 | Kenmore 23822 Top Load Washer
Mar 23, 2010 | Kenmore 23822 Top Load Washer
Washer empties faster than pipes allow causing overflow
More then likely you have a partial clogged drain also, New washer output is alot faster, Being a plumber its not getting enough air to let it drain properly. Check drain for clog and vent is wrking properly
Mar 01, 2010 | Washing Machines
Drain pipe overflows from washer
May 13, 2009 | Kenmore Washing Machines
My washer drain pipe overflows when draining. i've tried smaller loads, cleaning drain pipe & vent, and raising the drain pipe. seems like the washer is draining the water too fast.
Apr 30, 2009 | Washing Machines
Drain is not taling the discharged water away
check your hose by running a coathanger through it and, don't forget to check the vacuum breaker hose also
if you just installed a new garbage disposal did you remove the plug in the outlet of the new GD before you conected the hose to the DW? look into the GD when the DW is draining and look for the discharge stream
Apr 22, 2009 | Dishwashers
Washer won't fill up
The problem is most likely your drain. If there is no air break at the drain,( a gap where the hose goes into the pipe so air can enter) Your water will siphon out of the machine. Also make sure your drain pipe is higher than the tub of your washer and you only want about 6 inches of the drain hose sticking into the pipe. If you have water coming back out of the pipe when the machine drains, you will need a plumber to clean the pipes or replumb the drain. New washers pump out faster than older ones did and they need a good drain to handle the flow.
Sep 26, 2007 | Maytag PAV2300 Top Load Washer
Wash Machine Drainage problem
i am a recently retired appliance engineer of 20 years, slowing down the flow of water from any electrical washing appliances can be dangerous and will cause extensive damage to the appliance in question, at the very least it will stop half way through the cycle every time the only way to remedy this is to rectify the drain, or at least sort out another waste water outlet sorry
Sep 21, 2007 | Estate TAWB600JQ Top Load Washer
Water overflowing from drain pipe
The problem with the new washing machines, is that they dump 20-22 gallons of water in 4-5 seconds. This amount is far more than the garden hose test will submit the drain to. Here are a number of solutions, I hope that one of these will help you.
#1 As mentioned above, you can restrict the flow of the drain pipe. I recommend a 3/4" x 6" brass nipple, or a 1/2" x 6" brass nipple, depending on your specific situation. The brass nipple will not corrode like a galvanized nipple.
#2 There is also a rubber cap that you attach to the drain pipe that fits around the drain hose tightly.
#3 Some situations might require that you have to raise your drain pipe. It is recommended that it be at least 36". This allows for gravity to assist the drain.
#4 Some situations will require that the drain pipe be increase in diameter. Older plumbing applications were installed using 1 1/2" piping. With the newer washing machine discharge volume, the 1 1/2" pipes will not support the discharge. Your drain line will need to be changed to 2". This option will be one of the more costly fixes, depending on the amount of line that needs to be changed.
#5 Some plumbing installations installed without a p-trap will need to be changed. The p-trap keeps sewer gas from coming back into the house. It also allows for a smooth transition into the drain line. Any restrictions in the drain line (i.e. ells, tees,) will cause the soap in the gray water to foam up which will cause the drain line to slowly back up.
I hope these solutinons help.
Jun 03, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
234 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
