Question about Minolta DiALTA DI2510F All-In-One Laser Printer
Can I ask why when I make copy in the platen glass there is a black part in the left side of the paper and its 2 inches wide but when I copy in the ADF its clear and the copy is good.. Thanks for the
Black copy in the left side.
  • Minolta Expert
  • 1,326 Answers
I would have to say you will did to clean the optic's & make sure there is nothing blocking the path of the mirrors moving correctly. Good Luck
Posted on Dec 24, 2013
4 Suggested Answers
  • 73 Answers
SOURCE: black line down entire left side of paper
Its problem with tonner stucked in the outlet window of the cartridge. remove it by hands or buy new cartrigde
Posted on Sep 23, 2009
  • 1297 Answers
SOURCE: Copies coming out with three
Change the drum cleaning blade.
Posted on Jan 04, 2012
Cogz
  • 1326 Answers
SOURCE: ep 1030/1031F gets black strip down side of paper about an inch wide
Odds are you need a new drum cleaning blade. The only problem is trying to find parts for the copier. Good Luck
Posted on Apr 02, 2013
Why do my copies have black lines down the paper?
if its just copies clean the small glass to the left of the large glass its called the slit glass and is usally about 12 inches long and 2 inches wide if it comes out on prints as well as copies its a drum or fuser check to see which is bad another way to test if its the slit glass make a copie from the large glass if no line its definatly the sit glass
May 27, 2014 | Kyocera Epson Workforce Pro Wp-4530 Wp4530...
Panasonic dp3010 copier stripes on paper
Not exactly sure what you are asking but if the problem is that you are getting fine lines down the paper (the copy is ok though) then take a real close look atr the glass platen (the plate glass in which the paper goes on. Assuming you are using the ADF (Automatic Document Feeder) area. This area is usually about an inch wide by 8.5" long. Look for either "White out" or black ink on the glass (it can be as small as a dot) clean this mark off with glass cleaner and you problem will be solved. Sometimes it helps to orientate your copy with the line on it to the machine to locate the mark causing the issue.
Good Luck!
Mar 01, 2012 | Office Equipment & Supplies
B&w 6800 lots of horizontal black line areas. also, a vertical white strip about 3/4 inch wide about 3 inches from left side of paper
Hi!
the best thing is to make a copy using the glass and not the document feeder!If there is no lines on the copy simply lift up the cover and on the left side of the glass will be a thin strip of glass,Clean it with a dampened cloth and all line and marks should be gone1
Good Luck!
Apr 02, 2011 | Brother MFC 6800 All-In-One Laser Printer
WHAT IS THE PLATEN GLASS AND HOW TO CLEAN IT?
the platen glass is small glass on the left side of normal copy glass. The platen copy glass is used when you making the copies from ADF.
Hope that helps
Feb 13, 2011 | Canon imageRUNNER 1023N Black and White...
Black line in paper
On what operation are you receiving the black line in your paper?
This problem usually appears when you try to scan or copy using your ADF (automatic document feeder).
To remove this black line in your paper, clean the ADF platen glass in your printer and do as well in the flatbed scanner glass. This ADF platen glass can be found right below where the documents in the ADF goes through. Its a glass about 1 inch in with and beside the flatbed scanner glass (the one where your documents is lay down for copying and scanning. Dried ink or paper residue sticked in the glass can cause this line in the paper. Clean it with a a clothe and spray some windex on it.
Feb 10, 2011 | Panasonic KX-FLB801 All-In-One Laser...
Wide black line down page
open the document lid. Check to see if there is white-out on the glass platen where the document rides across the scanner. Some units require the white roll to be taken off.
sometimes a black mark on this platen can leave black streaks on copies made on this machine, and even when they send to others.
Try to clean the platen glass.
Oct 15, 2009 | Samsung SF-340 Plain Paper Inkjet Fax
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Scanner/Printer imageCLASS MF6550
Does it do it on prints aswell as copies?
If so open up the Left hand side door if you peer inside at the fuser (hot bit) can you see any damage. if so needs replacement.
Also could be the drum, look in the same area at the green/blue cylinder, these do up to approx 30,000 pages.
Hope this helps.
Mar 26, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Ask
Make on copy in the dockfeeder,and one copy on the platen glass.If you only have a line on the one copy make by the dockfeeder,the small glass next to the platen glass is dirty.Clean with spirits.
Let me know.
Oct 31, 2008 | Canon imageRUNNER 400S Copier
Black smudges across sides of 81/2 x 11 paper
The optics may be dirty or you could have a bad drum cleaning blade.
Feb 13, 2008 | Office Equipment & Supplies
Minolta DiALTA DI2510F All-In-One Laser Printer Logo
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
