Question about Vacuums
Bissel repair manual
My new vac belts brake as soon as I put them in
  • Vacuums Master
  • 18,392 Answers
Go to the link below for the manual
http://uk.bissell.com/Page_id/117/User_Guides.aspx
Posted on Nov 27, 2012
reddevil6
  • 1673 Answers
SOURCE: Bissell 3510 Vac with loud noise but not belt
Did you check the brush roll, may have a problem with it. But you could have a problem with a motor bearing going bad, they getting loud, also if there is a problem with the motor fan, that may be the cause of it being loud. Bissell 3510 either is obsolete or is thw rong number, it doesn't come up at the Bissell site.
Posted on Mar 18, 2008
  • 5 Answers
SOURCE: Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Posted on Dec 14, 2008
ukvacfan
  • 328 Answers
SOURCE: I don't know how to put on my belt to my Bissell
There are five screws underneath where the beater bar is. These need to be undone before you can open the sole plate up and get to the brush. If you still need help consider downloading this free pdf:
http://www.BISSELL.com/images/UserGuides/3130_1107.pdf
Dont forget to rate, thanks.
Posted on Mar 07, 2009
galati2k
  • 281 Answers
SOURCE: can't find replacement drive belt
go to bissell.com and look it up there.or call all-type vacuum and janitorial supply and ask for lisa or bonnie.tell them pete reccomended them.314-275-8006
Posted on Apr 28, 2009
Vac Belts
  • 701 Answers
SOURCE: repair bissell belt
Here is a link to the belts you need and a manual that you can view which has instructions:
Bissell 3910 Belts & Manual
Posted on Nov 09, 2009
How do you change a belt on the Bissell 5770
you can get a free manual at manualsonline.com
I just looked up your vac on page 5 of their list of manuals. Or you can open up your vac and see how the belt is on there and then you will see how to do it --- or you can take it to a vac repair shop and get them to replace it for about $12-15.
Hope it helps.
Kris
Feb 24, 2012 | Bissell Vacuums
The belt on my vacuum cleaner model 6596 bissel powerforce bagless turbo keeps breaking. As soon as I put on a new belt and start it up the belt snaps. It is the durabelt meant for this vacuum model....
I would guess you aren't centering the belt correctly, thus it's edge is caught between the brush and another solid object, causing the breakage.
When you get the belt on the the brush and the brush back in place, turn the brush a few times by hand to make sure it's not catching on anything. After you get the powerhead put back together, do this again. It's a common problem if the powerhead isn't assembled correctly.
Here's a video clip from the Bissell site demonstrating changing the belt.
http://www.bissell.com/how-to-videos/replace-brush-belt-vacuums/
Jan 08, 2011 | Bissell 6596 Bagless Upright Vacuum
My liftoff revolution smell like it is burning after I use it
That means that the belt is worn and is starting to slip. You need to replace the belt. Here is the belt you need and a manual you can view with instructions:
Bissell Lift-Off Revolution Belt and Manual
Mar 13, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
How do i put new belt on
Here is a link to the manual and to the belts you need. hope it helps!
Bissell ProHeat Manual and Belts
Nov 21, 2009 | Bissell 7901-R Clearview Proheat Plus...
It won't pick up. I cleaned all of the filters. what next?
I would try changing the belt. A worn, stretched or broken belt can cause the vacuum to not pick up well. Here is a link to the belt you need and the manual which has instructions:
Bissell Lift-Off Revolution belts and manual
Nov 17, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
My brush is no longer working on my bissell healthy home vac. when i try to turn it on it makes a high pitched squealing sound. I'm pretty sure it needs a new belt but my husband is having trouble getting...
According to Bissel, they should be standard phillips screws. Nowever - things change.
This is a general guide from Bissel for belt change -
BELT CHANGE _ CLICK HERE
Check your model number on that site for exact details.
If the screws are Torx (star) or other security screws, tool bits are available from Screwfix -
SECURITY SCREW BITS
That fit standard loose-bit screwdrivers.
Hope that solves your problem.
Thank you.
Sep 22, 2009 | Bissell Healthy Home HEPA Bagless Upright...
*&^%&^ Belt won't stay on
Hi Ecomama,
Check your Brush, it may not be rolling freely.  I had to clean string and hair and fiber out from ar0und the ends to get the brush to roll  freely.  This will cause the belt to get hot and come off.  just clean out the Brush ends.
Oct 23, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
