Question about Canon NP 6050 Copier
Result problem of 6050
The copier is copying but the result isn' clear enough in the middle of paper. and sometimes i got blur when copying a3.
    Scholar:
  • 62 Answers
You need to clean it up. first take out the main unit and then take out the transfer/separation unit. clean the wires with alcohol and make sure they dry off before putting it back on. it is more efficent if you change the wires (but gotta get them first of course)
then you should do an image intensity adjustment. about the blur on A3 i must know more details. if the rest of the main unit has toner remains you must vaccum it all. if oroblem persist then check ut the primary corona wire clean it or change it.
Posted on Jan 22, 2009
My ir3300 paper blur
Hi . You need to make this test . Try to print a report again. But this time open the front door in the middle of printing so the paper will stop between the drum and the fixing unit . The porpoise of this is see if the information is blurred before entering the fixing unit. . Is the information is ok before entering the fixing unit . You need to replace the grease of the fixing heater . If the information is already blurred before entering the fixing unit you need to check the laser unit. Probably dirty mirrors inside that unit .
Jan 27, 2018 | Canon Office Equipment & Supplies
Copy the results are less clear, was set darknes but its results are less clear.
replace toner, if not then replace the corona wire all, if not set the drum dens 7, if not replace the Primary H.V.T. Or P.O. pcb.
Dec 27, 2011 | Canon NP 6050 Copier
Make A3 Copy (Toshiba Studio 206)
If your copier didn't set any A3 drawer, then u need to insert A3 paper on bypass unit, on left panel select A3 (Original) to A3 (copy) b4 u press the start button. Otherwise paper jam will occur.
Apr 05, 2010 | Toshiba e-Studio 205 Copier
How do i copy an A3 to A3 paper
put a3 paper in the paper tray and adjust paper size wheel on trays righthand side so it says A3 doh.....................................
Jul 08, 2009 | Ricoh Aficio 2015 Copier
Paper pick up problem
hi,try to clean feed rolls,sensors.clear any misfeed sheet from paper supply area.send me a result.
thank you.
Jun 01, 2009 | Canon NP 6050 Copier
I want copy from A3 (2*A4 pages) to A4 (landscape)
While coping A3 paper it result in A4 portrait not in landscape which is incomplete.How to manage it?
Feb 19, 2009 | Canon iR 2016i Black and White Copier
Copy result is blur and I see the acceleration of paper too fast
When you say Blur? Is it a scattering of toner or is the whole image blurred or out of focus? You may have a problem with the lens HP or a problem with the scanning mirrors. Do you get a error code? Is the blur like toner strikes down the page? Check you corona wires and look for any small pieces of paper that maybe lodged in or around the drum unit. You may want to give a little more info. on the exact problem, to narrow down the cause
Dec 27, 2008 | Canon NP 6050 Copier
Canon 6050 copier
yes it indicates same message
Apr 14, 2008 | Canon NP 6050 Copier
A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Oct 02, 2007 | Sharp AR-161 Laser Printer
Canon NP 6050 Copier Logo
70 people viewed this question
old marine
old marine
