Question about Kenmore Top Freezer Refrigerator
My kenmore 106.74942400 icemaker is creaking. Help!
When I took the front cover off the maker the gear was barely moving. How do I fix this? Model 106.74942400
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
OK, you will need to replace the "control module" on the front of the ice maker. Here is the part to order.
Posted on Nov 27, 2012
  • 11 Answers
SOURCE: No ice from icemaker of Kenmore Elite model 106
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Posted on Mar 16, 2009
  • 744 Answers
SOURCE: Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Posted on Mar 27, 2009
SOURCE: kenmore icemaker does not work
Hand drawn of the GE # WR30X1009 found in 10-12 yr old Kenmore/sears/GE side by side refers. Couldn't find one ANYWHERE so forgive the hand drawn. Mine would not eject ice, intermintant. Bad microswitch on the on/off/vacation mode between the normally open side.
Posted on Apr 30, 2009
  • 103 Answers
SOURCE: Kenmore 106 50522 water leak from Icemaker
Hi: Usually if the ice maker malfunctions that bad it will keep running and flood bad. If your defrost drain is plugged it will puddle water. Without knowing how much water you see it is tough for me to say precisely. Does the ice bin have a big block of solid ice or cubes? If cubes I would guess it is the defrost drain at the bottom of the fridge. If the drain is clogged the water wont get to the pan to evaporate. If the defrost water has nowhere to go it will puddle. This would produce more water on the floor in a humid area than a desert like I live in. If so look at the bottom of the freezer in the back below the metal panel. Usually there are slots above it. There will be a hole at the bottom of a shallow rectangular funnel. Turn off the fridge and put your food in a cooler. Pour some warm clorox water in the hole, a fairly strong solution. It should eat out the mold that grows in the base of this non refrigerated line. If something like a frozen pea got in the line you might have to use a pipe cleaner to snake it out. Good luck with this, Jeff
Posted on Jun 01, 2009
carputers
  • 255 Answers
SOURCE: kenmore gsi-23 ice maker not working
is the water line hooked up to the unit ?
Posted on Sep 24, 2009
Installed a model# UKI1000AXX ice maker on a Model# CFB1921AR Magic Cher refrigerator. Can not get voltage to the water silinoid has been installed in the refrigerator for appox. 48 hours.
Yes you can check the voltage to the valve, but first a word of caution. To start the icemaker and let it cycle so toward the end of the cycly power will be sent to the valve, THE ICEMAKER MUST BE STARTED USING A JUMPER WIRE AND THIS COULD BE DANGEROUS AND RESULT IN YOU BEING SHOCKED IF NOT DONE CORRECTLY. If you chose to proceed and check for power to valve;
remove front cover of i/m
usea jumper wires about 16 or 18 gauge and strip both ends so about a 1/2" one wire is bare on each end
place bare ends into holes on icemaker front marked as T & H
the main gear will start moving,the jumper wire may have to wiggled to get a good connection
once gear moves and within 10 seconds you will hear a click REMOVE JUMPER WIRE AS SOON AS CLICK IS HEARD
the fingers on icemaker will rotate in a 360 degree rotation,if you think of the fingers as the small hand of a clock in about the 10 to 12 o'clock position their should be 120 vac at water valve if i/m is good. if 120 vac present replace water valve, if 120 vac not present replace icemaker
Aug 10, 2011 | Magic Chef (CSD2610KRW) Top Freezer...
Loud noise from JD-21 ice maker
Usually a stripped gear or a bad icemaker motor. Remove the icemaker front cover by using a flat screwdriver to pry it off between the bottom of the icemaker and the cover. Inspect the icemaker to see if the large white plastic gear has any broken teeth or is cracked in the middle. The motor is in the 10:00 position of the white gear. If the gear is ok, and the noise is coming from the motor, replace the motor.
After unplugging the refrigerator you can remove the motor assembly by removing three screws in the mounting plate, and then two screws holding the motor on. The parts house also sells the complete icemaker, however your refrigerator is already 29 years old if I am reading your model number correctly. Good Luck, Appliance Specialists
Jan 01, 2010 | Kenmore Refrigerators
Ice maker stopped working
if you will remove the front plastic cover on the icemaker take a look at the drive gear. see if the 2 center pins are still present this is a common problem one of the pins will break off causing the gear to pull loose and loose electrical contact for the icemaker motor. replacing the motor module partnumber 8201515 will fix your icemaker thanks for using FixYa Peyton
Feb 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Adjustment screw on side of Maytag icemaker???
No. That setting changes the size of the cube.
Jan 20, 2009 | Refrigerators
Ice maker has ice in it but will not dump in bin!
before i would worry about the lights flashing lets pull the front cover off of the icemaker and verify that the drive gear is not broken.
on the bottom of the icemaker is 1 screw. remove that screw then just slide the entire icemaker out of the refrig so that you can access the front cover. if the gear is broken just replace the front motor module pt# 8201515
if the gear is fine then located in the toe grille of your refrig is a tech sheet that will help you troubleshoot red light blinking.
Dec 17, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not working
the icemaker will run at 120v ac +- 10% so 108 v is within range altho marginally. since you have the icemaker removed. remove the front cover and check to see if the drive gear is broken or if the 2 center pins that hold the gear in place are twisted or broken. this is most likely the problem. the motor module can be replace very easily part # is 8201515
the normal home position for this icemaker is at the 2:00 position facing the front of the icemaker. if it is any other position the motor module is almost always the culprit..
Dec 17, 2007 | Refrigerators
pull the front cover off of the icemaker and see if the drive gear is broken (there are 2 tabs in the center of the gear make sure these arent twisted or broken as well) if so replace the module on the fron of the icemaker. if that checks fine check for frozen fill line..
Dec 16, 2007 | Refrigerators
DOES NOT MAKE ICE
yes. remove the cover of the icemaker. if you have brown head on the ice maker with a large white gear in the center, look to make sure both tabs in the center of gear are intact. you should not be able to move this gear at all. if you can the the icemaker isnt tell the valve to put any water in it. replace icemaker head. if it is tight, no movement at all then replace water valve
Nov 26, 2007 | Refrigerators
Kenmore Top Freezer Refrigerator Logo
123 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
