Question about Frigidaire Dryer Thermal Fuse Thermal Limiter - 134120900
Dryer is not turning on
At first my dryer was having difficulty turning off when the door was opened, it would continue to run. Then once it cycled out, meaning it turns off. Now it will not turn on, though I hear a soft clicking sound from the off and on button ares. I was told it could be the thermal fuse and a replacement would fix this problem
  • Frigidaire Master
  • 8,220 Answers
That sounds like a bad door switch to me. My Frigidaire dryer service manual and more is HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 27, 2012
SOURCE: dryer power
your motor is fried
Posted on Dec 01, 2007
exspert
  • 55 Answers
SOURCE: Dryer not turning on
ok " the timer has points that act like a switch , they get burt and will not work after a long time
replace time , it's just a plug in unit
Posted on Jan 21, 2008
vanni7
  • 163 Answers
SOURCE: Whirlpool Dryer GEQ9800LW0 won't turn on
Hi!!! it seems that you have a bad thermal fuze located near the blower..change the thermal fuze and you should be okay..Good luck..
Posted on Jan 04, 2009
dniro592006
  • 121 Answers
SOURCE: LG DLE7177 Thermal fuse
Thermo Fuse is normally followed by the power source or on
the circuit board, Follow power source and you will find fuse.
Posted on Apr 02, 2009
SOURCE: Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Posted on Sep 22, 2009
Why does dryer continue running after dry cycle finished?
I would say this is in the control board but not 100 percent on this. If you go to an appliance store, not a big box, they will probably help you diagnose and order the part for you if you want to do this on your own.
Feb 09, 2016 | Dryers
My dryer works fine...heats tumbles the timer just doesnt advance once it starts therefore the dryer wont turn off on its own
the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 11, 2014 | Whirlpool LEB6200 Electric Dryer
Lg dryer wont turn off
If the dryer continues to run when you open the door you will need to replace the door switch. Here is the part to order.
Nov 03, 2012 | Dryers
Aeq6000 won't turn off
This has to do with the control board failure. The control board runs every aspect of the dryer and will need to be replaced. Here is the new control board.
Oct 20, 2012 | Frigidaire AEQ6000ES Electric Dryer
When door is open during drying cycle, dryer continues to heat up.
no,it sounds like the heating element is touching metal and as long as the timer is sending power until it goes to off it will keep heating.change out the element
May 21, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer drum is turning, but not drying the clothes. When I open the door, there is heat. Lint has been cleaned out
Check where the dryer vent comes out and make sure that there is a good amount of air coming out. If the fan is blowing, the drum is turning, and there is heat, the likely thing is that the dryer vent is partially blocked. Check the pipe leading out. Bird's nests are not uncommon. The only other thing I can think of is that the door catch is wearing out and the door is popping open, shutting the dryer off mid-cycle. Some dryers will continue to run the timer if the cycle is interrupted and it will appear that the dryer ran its full cycle, but in reality it shut off soon after it started.
Dec 06, 2009 | Whirlpool Inglis IP8200 Dryer
My Whirlpool dryer is plugged in but will not turn on
I would start by checking to make sure the circuit breakers are not tripped. An electric dryer runs on 220 and will have a double circuit breaker - a gas dryer runs off of 110 and will usually not have a dedicated breaker. Once you have determined the power is on, the next most likely problem is the door switch. This prevents the dryer from being activated with the door open. You can "jiggle" the switch while attempting to start the dryer, or check the continuity with an ohmmeter.
Jul 20, 2009 | Whirlpool Dryers
Dryer timer still runs after auto-cycle is complete.
can you just leave the door open when not in use???????
Mar 30, 2009 | Kenmore Dryers
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
Frigidaire Dryer Thermal Fuse Thermal Limiter - 134120900 Logo
64 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
