Question about Sony FD Trinitron WEGA KV-36HS420 36" TV
My sony won't turn on (wega)
My sony trinitron's indicator light blinks 7 times when i attempt to turn it on and then it shuts off. i'd like to know what parts to buy, how and if i can fix it! thanks
  • stix134_girl Jan 20, 2009
    I have the same problem. I had a tv repair service come to my home to repair it. Some kind of Panel was messed up and and it is going to cost $402.05 to fix
  • Sony Master
  • 8,457 Answers
Ur high voltage is dead,FBT,flyback transformer is dead.The big block of plastic with a red wire with a cap hook to the CRT(tv tube).
Posted on Sep 28, 2009
Sony trnitron tv won't turn on. stand by light blinks. Any ideas?
watch the blinking light---if a specific sequence like 7 blinks a pause and repeated endlessly that is a error code. It will not point to a specific part but will indicate where the issue might be.
Dec 19, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron KV-40XBR800 wont turn on
30 YR SERVICE TECH.
YOUR UNIT IS EXPERIENCING A POWER SUPPLY FAILURE.(INTERNALLY)
TAKE TO A SONY AUTHORIZED SERVICER.
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv won't turn on
Ur high voltage is dead,FBT,the flyback transformer is dead.The big block of plastic with a red wire with a cap to the CRT(tv tube).
Jan 10, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
SONY WEGA KV-36HS420 will not come on
The blinking is an indication that the set detected a problem. The code usually indicates a bad regulator circuit. If yu can solder, you can probably fix this your self. Please let me know if you wish to attempt the repair. If not, expect a parts cost in the $25-$40 range plus the local labor rate for the repair.
Oct 01, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony Wega Trinitron KV-32HS20 TV
The 4 blinks usually indicate a vertical problem. If you can solder, you can fix this yourself. Let me know if you wish to attempt this repair. If not, expect a parts cost of $10-$15 plus the local labor rate for the repair.
Dan
Oct 01, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Wega KV36HS420 keeps turning off mostly when commercials come on. The red light blinks 7 times what is the problem? Can I fix it?
The 7 blinks indicate a high voltage shutdown condition. The high voltage has exceeded 33000V. This is usually due to a faulty regulator in the power suplpy circuit. If you can solder you should be able to resolve this.
I'll look up the specific part and update this if you feel you want to try.
Let me know.
Dan
Jul 08, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA KV-36HS420 36" TV Logo
219 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
