Question about Motorola Mobility H730 - Headset over-the-ear - wireless - - 89422N
Static on h730 head set
Bad static on the receivers end
How do I fix a static/sound problem on my LG optimus Exceed 2?
Use it from different locations and see if it happens everywhere. That problem is commonly related to bad channel on the cell towers.
Apr 11, 2015 | Verizon Wireless Prepaid LG Optimus Exceed
How do I sync my phone with the H730?
Turn off H730,
1) have you ever paired the H730 to any other devices? if so make sure those devices are turned off.
2) Next make sure that your phone has bluetooth featured turned on.
3) Turn on the H730, if there is no devices that the H730 headset can pair to, it should go into descovery mode, the headset light should turn a steady blue, and you should hear "ready to pair"
4) At this point go to your phones bluetooth options and search for bluetooth devices. The H730 should show up
5) It then should ask for a password, 0000
6) after entering the passcode the H730 should say pairing complete
Make sure that it is fully charged, usually takes about an hour to charge completely.
Mar 11, 2014 | Motorola Mobility H700 Wireless Headset
My h730 pairs up but i get no sound. no beeps or woman voice to let me know its on. what should i do
Even when you are on a call? Do you hear anything when you receive a call and answer the call?
Mark
Motorola Support
Feb 22, 2014 | Motorola Mobility H730 Bluetooth Headset
MY BATTERY DIED, I CHARGED IN CAR AND NOW I CANNOT GET ANY VOICE PROMPTS ON THE HEADSET TO WORK AND IT WILL NOT PAIR
I think I am having the same issue:
When you open the H730 up do you hear beeping noise instead of a womens voice. Also does it stay on until you open it for a second time.
Sep 03, 2013 | Motorola Mobility H730 Bluetooth Headset
Electric shock when leaving car
Although it's possible that there is an electrical problem in your car, it's more likely that the shock you're feeling is naturally occurring static electricity.
If your tires were replaced as part of the front end repairs, it's possible this is the cause. Cars naturally build up static electricity from rolling around on rubber tires (the same thing that happens when you rub a balloon on your hair). This static used to get dissipated through the tires to the ground -- however, new, fuel-saving tires with lower rolling resistance are made of a rubber compound that doesn't dissipate static electricity as well as the old stuff. (The price we pay for better gas mileage.)
The static builds up in your car, and then gets discharged through you when you get out of the car and complete a circuit between the car and the ground through your body.
One solution is to attach a ground strap to your car. You can buy these rubber strips from most auto parts stores. One end attaches to a metal part on your car. The other end drags on the ground and dissipates static through it, rather than through you.
Sep 13, 2009 | iLO XM-MP3-CD Car Stereo
NES screen static
You hit the nail on the head! Whats probably happened is that the ground wire on the coaxial cable is not making a good connection with the end piece and therefore not getting a full signal to the TV. Try AV cables good luck!
Apr 27, 2009 | Nintendo NES Console
Motorola Mobility H730 - Headset  over-the-ear  - wireless - - 89422N Logo
37 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
