Question about Evga 112CKNF72K1 Motherboard
Not start windows. not blue screen, , only works procesador fan, hd and periferic
  • 3,799 Answers
Check your RAM.
Posted on Nov 28, 2012
MI PC DE ESCRITORIO DEJA DE FUNCIONAR DE REPENTE, EL MONITOR QUEDA EN NEGRO. CARACTERISTICAS: HP PROCESADOR: AMD Athlon(tm)IIx4650 PROCESADOR 3.20 GHZ SISTEMA OPERATIVO 64 BITS WINDOWS 7 HOME...
If your PC is still powered up but stops working (you can tell that the power supply is running), then it is likely the fan on your CPU has failed and as soon as the chip heats up it stops. This can be deadly to the chip so get it repaired as soon as possible. Another possibility is the fan inside the power supply will produce similar symptoms. Good luck.
Aug 29, 2013 | HP Computers & Internet
Blue screen tells me to disconnect driver. New hardware sign comes up then get blue screen. Restart and press F8 but blue screen returns
f-8 will get you into safe mode,that is basic boot minimum periferals,i would go into safe mode delete drivers,reboot normally and follow instructions for install.good luck!
Jan 08, 2011 | Western Digital My Book Essential 1TB...
I HAVE A AVERATEC 3225HS THAT WORKED GREAT TILL I TURNED IT ON YESTERDAY. THE INTRO SCREEN CAME ON AND THEN IT WENT TO A BLUE/BLACK SCREEN LIKE WINDOWS WAS GOING TO START BUT IT NEVER DID. I CHECKED THE...
I had a Toshiba, did almost exactly same thing. What I think is happening is the computer gets stuck in a loop because of a corrupted driver or maybe virus. It works harder and harder, but goes nowhere.. only getting hotter. Since you cannot get to the system, even in safe mode, to fix it, the next easiest thing to do is to reload the OS windows, formating the HD as you go. There are ways to boot from a CD and run AV sofware, but that's usually difficult at best.
You could try booting off the install CD and do a repair. That might get you running long enough to do a virus scan. Mine had the install OS on a partion on the HD, so I ended up wipeing out the C: and reloading from scratch. Took about 3 weeks to bring it up to my version of normal... (Hate that vista)
Good Luck.
Dec 24, 2010 | Averatec 3225HS (DH3225HS) PC Notebook
When I restart my laptop to my HD crashes when windows starts to start, she took the laptop outside and put on another laptop to back up, but when it starts copying, the screen goes blue and restarts...
You will have to take the drive off, put it on an external hdd enclosure with a usb connection, connect it to a working computer, scan it for viruses and spyware, copy all of your data to another device (i.e. hdd, flashdisk, cd, etc). Then, reinstall the hd back on to the original computer and turn it on. If it works it you've solved your problem. If it doesn't then reformat your hdd, reinstall your operating system, programs, and data.
Time consuming? yes but it works.
Aug 17, 2010 | Computers & Internet
Radeon HD 4850. I get a blue screen every time I turn my PC on. It says something `atikmdag.sys` and it's counting to 100 and then the computer restarts. This blue screen it only happens after I install...
Blue screens are software related errors. You would need to try to start the PC in protected mode and remove the drivers from the registry and/or the startup. If possible, run the system restore and put it back to a prior date before you tried installing the drivers. It's possible you may have a card that will not work with your system.
Jun 13, 2009 | Computers & Internet
Porque mi placa se recalienta tanto donde se encuentra el procesador y la tarjeta de video
Hola te recomiendo un sistema de este tipo, ami me pasaba y con esto se soluciono ese problema http://www.bit-tech.net/hardware/cooling/2012/09/26/thermaltake-water-2-0-performer-pro-reviews/1 9ab6aa7c-9dc3-4642-ab5a-d10391656423.jpg
Oct 01, 2008 | Intel D865GBF Motherboard
Black screen at power on
I had the same problem. I pull of battery and then immediately reattached and ta-daaaa! Windows came right up!
Hope this helps!
gg
Jun 23, 2008 | Samsung Q1 Tablet PC
Blue Screen with error messages
Startup your laptop keep clicking f8 until you see option like star in safe mode just click on "LAST KNOWN GOOD CONFIGURATION(your most recent settings that worked)"
Simple as that ;-).
Dec 29, 2007 | Dell Inspiron B130 Notebook
Evga 112CKNF72K1 Motherboard Logo
Top Evga Computers & Internet Experts
Tony
Matthew Spark
Matthew Spark
David
David
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
