Question about Maytag Washing Machines
Drains to fast water overflows out pipe never happen with any other washer I had in 30 yrs
Maytag centennial commercial tech model# mvwc400vwo I tried a longer no luck thanks
SOURCE: Water overflows from drain pipe
on the drain go down 6 inches ,add one 90elbow,extend up to the height of the original drain.should relieve the air that is pushing the water out.
Posted on Sep 13, 2008
  • 351 Answers
SOURCE: my washer drain pipe overflows when draining. i've
no you have a drain problem .... i would recommend calling a plumber the only thing it could be is drain problem there is no such thing as draining to fast.
Posted on Apr 30, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: drain pipe overflows from washer
Something is blocking the drain and it can't keep up with the flow now. You can try cleaning the drain with an auger (available for not much money at home supply stores). You'll probably find a sock or lots of lint built up.
Posted on May 13, 2009
barkencoa
  • 3463 Answers
SOURCE: the water drains too fast and overflows
Any washer cannot drain too fast, the problem is in your drainage pipework, there is likely to be a partial blockage or restriction of some kind, it means rodding the pies, or taking it apart to clean it.
Posted on Mar 24, 2010
heatman101
  • 43501 Answers
Here is a tip that will help you with that problem...
Changing or Upgrading your Old Washing Machine
http://www.fixya.com/support/r4696582-changing_or_upgrading_old_washing_machin
heatman101
Posted on May 17, 2010
Tip
Clothes Washer won't stop filling with water?
If your washer continues to fill with water and does not overflow onto the floor where is that water going???
The water is siphoning from the machine as fast or faster than it it filling. This is caused by one of two situations both have to do with how the drain hose is routed.
The most common is that the drain is too low. The drain for your washer must first rise above the height of the tub or highest water level before it enters the house drain or drainage sink. This height is typically a minimum of 30". So if you are trying to drain the washer into a low pipe, a short sink or down hill you must first raise the hose or piping to that 30" before it heads down hill.
Second cause is where the drain hose is pushed too far into the house drain. A typical drain pipe in the home has a water trap at the bottom. If you put your washer drain hose down into the pipe too far and contact the water in that trap you will also siphon the water from the machine. The drain hose should hook and be secured to the drain pipe and go inside about 6", that's all that is needed.
Other washer issues:
SUDS http://www.fixya.com/support/r4621260-many_suds_in_clothes_washer
ODOR http://www.fixya.com/support/r4621314-odor_from_towels_or_clothes_washer
Control Locked http://www.fixya.com/support/r4624473-control_locked
on Apr 23, 2010 | Washing Machines
How do I fix my Maytag Centennial commercial technology washer.
No agitation? first use a meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good. now take the original hose tube and plug one end and blow into it the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? sometimes they get busted open or a pin hole and release air causing the water switch diaphram to not open. if both check ok then next the motor coupler or belt if belt driven. check with a multi meter for continuity the door switch, and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Mar 28, 2015 | Maytag Washing Machines
Washing machine not spinning, clothes are very wet when washing is done.
Check the drive belt. Sounds like that could be the trouble.
Mar 09, 2015 | Maytag Washing Machines
Specs for model#MVWC400XW0 Maytag Centennial Washer
It definitely could be a clogged or bad pump. However, it's always a good idea to check for error codes before replacing a part...Especially expensive ones...
http://applianceassistant.com/Washer-Repair/Maytag-Centennial/Maytag-Centennial-Washer-Error-Fault-Codes.php
Hope it helps! Good luck!
Mar 02, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Centennial Top Load Washer drains as it fills.
The water is probably siphoning out of the tub. Your drain pipe is either too low or the drain hose is down too far into the pipe. Take the drain hose out of the pipe and lift it high. I'll bet your problem goes away
Feb 06, 2014 | Maytag Centennial Top Load Washer
Washer overflow from drain pipe
If the water continues when electricity is discontinued the soleoid valve is jammed open, a fleck of rust or something, not designed to be repaired, it is easier and cheaper to replace. they are a standard part that fits 99% of all washers ~$10-20 at the local parts guy.
Usually only the cold solenoid has failed. it gets used more often.
If you are like me and only use cold water, swap the hoses on the taps, and swap the wire connectors on the solenoid valves, so the former hot is now cold, and you will get about the same number of years before you have to replace anything
Nov 27, 2012 | Maytag Washing Machines
My Maytag washer pumps water out of the washer faster than it will drain out of the stand pipe. Is there a way I can reduce the rate the water comes out of the washer? George
No sorry thier is no way to reduce the rate of drainage..the standpipe should be able to handle it,what i believe the problem is that the standpipe is partially blocked and needs to be snaked out to clean it or try some liquid plumber to clear the restriction in the pipe
Aug 31, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
