Question about Konica Minolta Office Equipment & Supplies
Dialta di 2510f black part
Good morning, can someone help me regarding the problem that I encounter with this machine regarding the copy with black in the left side when I copy in the platen glass but if I make the copy in the ADF it is clera and I dont see and black? Thanks..
  • Jomz Nov 30, 2012
    The drum and cleaning blade of the machine is new I already replace it. The problem with the black shade in the right side of the copy only occurs when I make the copy in the platten glass but if I make the copy in the ADF the copy is good. The machine is brought from new zealand. Maybe the problem is the firmware as of the last commenter.. Thanks for you help guys... Hope to solve it soon..
    Problem Solver:
  • 11 Answers
Try to cover it manually with a plain white board when your copying, not using the actual cover of the machine. if the black not appear, you have to adjust the white thinggy on the cover where the side you have been troubling.
Posted on Apr 17, 2013
SOURCE: canon ir5000
i think you have the european version, which is the adf doesn't able to read the fls size. A paper longer than a4/letter will be detected as legal. It was the firmware of the copier that makes this problem.
The solution is : You can "shift" the result, by pressing "additional function" than "shift", press "<-" (left) before make a copy with adf source. The result will be shifted up about 0.9".
And the bottom page will be still copied as well.
good luck.
Posted on Apr 08, 2008
  • 33 Answers
SOURCE: Black smudges across sides of 81/2 x 11 paper
The optics may be dirty or you could have a bad drum cleaning blade.
Posted on Feb 14, 2008
  • 86 Answers
SOURCE: 1/8 black stripe
Has the drum reached the end of its life/damaged
It may also be the drum cleaner blade is dirty or needs to be replaced. Check these and if the problem persists please get back to me.
Thank You
Posted on Feb 19, 2008
Cogz
  • 1326 Answers
SOURCE: konica minolta bizhub 501
The problem is that the default setting ing the copier has been set to all ways do two sided. Ckeck your user settings just go through all the screen and look for orginal doc. setting, it should be set for simplex or one sided. If it is not there you may have to call your service rep. and have them change the setting in service mode. Some of the older and newer copiers have a setting in service mode. It is most like in your user settings. Someone was Panic Botton Pushing & will not fess up....Good Luck
Posted on Oct 09, 2008
firecontrol7
  • 6674 Answers
SOURCE: change the display language minolta dialta Di-350f
1. User's Choice Function Setting Procedure
<Procedure>
1. Press the Utility key.
2. Touch the “User’s Choice” key.
3. Select the appropriate screen from the menu.
4. Select the appropriate function.
5. After the settings are complete, touch the “Enter” key to validate the settings:
User’s Choice 1/6 Language Selected, (third one down)
Posted on Jul 31, 2009
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
I have Printer refill powder in plastic bag, can i use it to refill some printers catridges or i need machine to make refill ink?
whats the model no of the machine? ink and toner are 2 totally diffrent things one is a powder and other is a liquid
Sep 25, 2013 | Konica Minolta 8936-488 Developer Model...
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
open the front door, upper left small access cover remove. press trouble reset. if the code comes back do not reset problem with the fuser continue reset fuser can catch one fire the will ruin a perfectly good day. have the fuser checked out.
Feb 02, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
Dialta di 152 error 0L ; i can not print and can't copy.
ol mean there's a door which is open, try to check ur front door and right side cover if its open, dn. if ok, there something wrong with the door swithc
Nov 11, 2009 | Konica Minolta DiALTA Di183F Copier
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
Looking software for Minolta DiALTA Di183
all firmware and drivers for the di 183 will be on www.konicaminolta.com this machines uses a pi 1802e controler look for this and not the model of the machine for the drivers
May 22, 2008 | Minolta DiALTA Di183 Copier
44 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
