Question about Zenith Televison & Video
My zenith tv wont turn on
Model number z42pq20-uc
5 Suggested Answers
toddthetvmd
  • 101 Answers
SOURCE: jacks show in black and white
You need component output on your Wi. You should have 2 AV jacks on your TV. I am guessing you have a red,white ,and yellow for your WI? That is made to hook up in the AV and NOT the component.If you have red,green,and blue? You might just have a bad cable,that is why it is in B&W. Or hook your Wi to your suround sound AV input if it has one. It is hard to give you all the answers with the info you provided.
But this is a educated guess. hope it helps. Todd
P.S. Be carefull with your controlers, SEVERAL accidents of them hitting the TV and breaking the screen. Play nice. :)
Posted on Jan 15, 2010
  • 3230 Answers
SOURCE: Where can i find a replacement remote and manual
Well you can please follow the below link for manual -
http://c.sears.com/assets/own/05775849e.pdf
And follow the below link to purchase a remote -
http://www.replacementremotes.com/ZENITH/Replacement-Remotes-New-OEM-TV-DVD-Remote-Controls-page-1.html
Good Luck!!
Posted on Mar 31, 2010
walesarumi
  • 6993 Answers
SOURCE: lg model number is 50 PX1D-UC TV does not power
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors) http://www.shopjimmy.com/.
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Take care.
Posted on Jan 22, 2011
dduncan774
  • 760 Answers
SOURCE: i have a zenith z42pq20
Sounds like you took a hit. Unplug your set for 30 minutes and plug it bcck in. It could have just locked up the micro. If this does not fix, unplug the set and take the back off. Plug the set back in and check the powersupply for your 5 volts dc. If it is there, replace your main pcb.
Posted on Jul 20, 2011
How can i find out more information about older zenith t.v. ?
IF you have the serial number you should find the model number.
The model number is essential for getting more information. One trick is to put 'old Zenith TV images' in Google. You will get lots of pictures. Find the pictures of yours and some will have the model number stated. From there you can do search on that model number. You should be able to locate manuals, etc.
Jun 29, 2014 | Zenith Televison & Video
Z42pq2-uc hdmi not working
depending on complete model# the pt # varies & price varies between $80.00 & $100.00
See the following link:
http://www.shopjimmy.com/zenith?master_part_type=Main+Board&q=Zenith&tv_brands_select=Zenith&tv_models=Zenith+Z42PQ20-UC
Apr 16, 2014 | Zenith Televison & Video
Tv wont turn on
Hello
If there is no power light on the front panel of your TV, ahen you switch it On, the power supply to your tV should be troubleshooted. You haven't given its exact model number here. If so I might send some more details that may help you. Usually, power supply regulator boards fo these type of TVs will have no repair to it, and should be replaced as card basis. OK
Feb 07, 2012 | Zenith Televison & Video
I have a zenith z42pq20 about a year and 3 month yesterday a hear a thunder, my tv was on, there.s a power failure and then the standbay light turn red but the tv doesn't turn on. The light doesn't...
Jul 20, 2011 | Televison & Video
Hi. I have a Zenith 42" plasma TV - Z42PQ20 that's
I had this exact problem on my TV, everything said it was the power board. It wasnt, luckily i was able to return that board. It was the YSUS board.
I should have done this this first but this is how i verified the old power board was good. Unplug TV, take the cover off and disconnect the wire harness going to the YSUS, plug TV in and turn on. If led stay blue its the YSUS.
Mar 19, 2011 | Zenith Televison & Video
Zenith 52" LCD. When the lamp goes out does the sound go out also? Tv wont turn on and the power and lamp light flash red. no sound.
Has Lamp been replaced? Also if Blaster board is bad Lamp will not turn on also CK Fan behind Lamp If it is not running Set will not turn on For Parts Try Encompass 1-800-639-3328 or look on line www.Encompass Parts, Also Look on E-Bay for Lamp and Blaster Board I found Lamp fot mine for 85.00 and blaster board for 55.00Type in Model number it will be on back of your TV.
Nov 10, 2009 | Zenith D52WLCD 52" Rear Projection...
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Televison & Video Logo
53 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
