Question about Refrigerators
Refrigerator model bx21vl does not cool. I can hear the compressor kick in but it kicks out in 5-10 seconds. Then after about 102 to one minute it kicks in and out again,
Refrigerator and freezer quit cooling, I can hear the compressor try to kick in but after 5-10 seconds it kicks out. Then after about 1/2 to 1 minute it tries to kick in again but keeps kicking out.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Compressor is tripping on overload. You may just need the overload and relay replaced due to a bad compressor relay. The relay is what switches the compressor from it's start winding to it's run winding. If you pull the relay off, shake it to see if you hear lots of rattling inside, that's a sure sign of a bad relay. I would replace both of them.
Here is the overload relay to order.
Here is the start relay to order.
Posted on Nov 27, 2012
tborn6
  • 700 Answers
SOURCE: Kenmore side by side refrigerator/freezer is not cooling
http://www.appliancerepair.net/apnet/frameset?
http://www.appliancerepair.net/apnet/refr/ch05.htm
try this site for the aanswers that you seek
Posted on Jan 23, 2009
  • 125 Answers
SOURCE: Whirlpool refrigerator model ED5GTN cooling problem.
With the unit unplugged, take off the back cardboard panel. On the lt rear side you will find the compressor. On the lt side of the compressor you will see a white box mounted on the side, this is the relay, and it most likely will have a zip tie holding it on. Cut the zip tie or unhook the clip. Gently pry the relay from the side of the compressor. If it is badly burnt make sure there are 3 connectors on the compressor, sometimes they will burn one off or burn it so bad the compressor will need to be replaced $$$$ if not in warranty. If its not burnt thats hopefully what you will find, hold out your hand with the compressor side of the relay pointing down. Shake the relay like a salt shaker into your hand. If you get grey flakes/chunks in your hand the relay is bad and will need to be replaced. easy fix for about $45 - $50.
Posted on Apr 18, 2009
  • 358 Answers
SOURCE: Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
Posted on May 01, 2009
SOURCE: freezer working but refrigerator is not cooling
if freezer is close to zero, top to bottom, and fridge is warm(ing), then you likely have a defrost problem, you will notice an abundance of snow/frost on back wall of freezer. it could either be your heater, thermistor, defrost safety thermostat, or your defrost control/main cpu, depending on model. if either or both sides are warm at the top, and cold at bottom, then your freezer fan is out. again depending on your model, it may just be the fan, or a combination fan/main cpu board hope this helps
Posted on Feb 15, 2010
  • 86 Answers
SOURCE: Refrigerator side not cooling
I'm not there to check it. It sounds to me from what you are stating that it is going off on the overload. This would happen from a locked rotor. A sharp hit on the compressor shell with a hammer might get it to work. If only for a little while. You may need a new compressor.
I hope this helps.
Posted on Apr 20, 2010
My refrigerator kicks on and off but will not cool below 48 degrees
It may be kicking off on low gas, or the cap tubes or the evaporator valve is malfunctioning. A professional technician will have to check it out.
Dec 02, 2013 | Frigidaire PLRU1777DS Stainless Steel...
Compressor kicks on then kicks off in a second or two. Cooling a little in the freezer. Not cooling at all in the Refrigerator. It is a side Xside.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 18, 2011 | Whirlpool Refrigerators
GE TFF24RC- Has lost its cool, will not re-cool, hear compressor kick on, but after 2-3 seconds it kicks off, and repeats about every 3-4 minutes. I am thinking it is shot, but there is always some slim...
heatman101
May 07, 2011 | Refrigerators
Maytag/Mod MSB2354GR SER # JSU18X156A0A compressor kicks on but kicks off again. after 2 or 3 seconds . on again/off again No cooling in either side Cooling fan runs all the time
heatman101
Mar 15, 2011 | Maytag MSB2354G Side by Side Refrigerator
Maytag MSD2351HEB sidebyside occasionaly goe thru frequent cycling buzz. Last for a couple of seconds, then repeats a few minutes later. sounds like a solenoid click when going off.
if this model has the techumse compressor it is probably drawing high amperage and kicking out. the click and buzz is the compressor winding stressing to draw the energy needed. compressor maybe bad. the compressor model usually starts with a t11...
Aug 01, 2010 | Maytag MSD2351HEB 33" 23 Cu. Ft....
Frigidaire Refrigerator not cooling
Is the fan on the bottom on? Do you hear the compressor kick off and on within a minute? No/ Is the evaporator fan running? Do you have frost on the evaporator? Frost is a sign that the defrost isnt working. If evap fan doesnt run it wont cool the refrigerator. If everything is running and no frost buildup in freezer then you have a sealed system problem and need of a tech.
Jul 25, 2009 | Kenmore 50522 / 50524 Side by Side...
Compressor not kicking in when i turn the air conditioning on.
what is the make and model? how long has it been switched on? is the compressor top hot?
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
Sanyo Eclipse refrigerator (Model# SR-4433S)Has puncture hole in Freon Tray for freezer. Does anybody sell replacement part?
HI thanks for the question. if theres a puncture in the coils . scrap it way too expensive. sorry.
Oct 15, 2008 | Sanyo Refrigerators
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
