Question about Kenmore Freezers
Kenmore upright freezer 253.23425100 does not cool
Freezer runs, but the air is warm.
aborcass
  • 2651 Answers
SOURCE: Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Posted on Mar 03, 2008
  • 311 Answers
SOURCE: Freezer not Freezing
If unit is running then it is not worth fixing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
kachbibi1
  • 979 Answers
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Posted on Feb 17, 2009
SOURCE: I bought a used Kenmore upright freezer, it's been running all the time.
I'm Not a pro, but the comments refer to a refrigerator. I don't think they read your problem from start to finish. I went to RSI in Phoenix, and I would say it is low on refrigerant. I hope it's 134a.
Good Luck
Over the years the freon sloowly leaks out, it might need only an ounce or two but it will fix it in my opinion. I have the same problem with mine.
Posted on Jul 29, 2009
Controlfrk
  • 304 Answers
SOURCE: Kenmore 253 9280413 freezer keeps running
The coils are embedded in the outer walls and will make the cabinet feel warm outside when the compressor is running. It needs about 4 inches of clear air space around all the outer case walls to properly get rid of its heat. If you have items stored too close to the outer walls they will act as insulation to keep heat from being dissipated. This can cause long run times.
A unit that has lost freon gas due to leakage, while unlikely, can also extend run times. Normal temperature should be about Zero when the dial is set to halfway.
Good Luck
Posted on Sep 17, 2009
Whirlpool freezer cool air but not freezing?
Check the seal first. Then check the freon. If it's R-12, you can go to the auto parts house. They have a bottle with a hose to add freon. You put it in on the "suction" low side with the unit running. you can tell when it has enough by feeling the low line be cold and teh high pressure line is warm to hot
Jun 06, 2014 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Mdle 21571 upright Kenmore Freezer seems to run all the time and seems warm to the touch. It is keeping cold but the running all the time doesn't seem right.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 02, 2011 | Kenmore Freezers
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
Brand new upright the back wall of freezer has a
i have filled polythene bags with paper scunched up inside.to fill any empy drawers this will stop all the cold air escaping and being replaced with warm damp air.....works for me.....
Feb 01, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Is it safe to put a upright freezer in the garage?
As long as it's not exposed to the weather it won't hurt it although there can be problems with the cooling in colder temps because the sensors can detect the cold outside air and quit cooling.
Oct 17, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Good Luck
Sep 15, 2009 | Freezers
Upright Freezer self defrosting
THE (SUCKING AIR) OCCURS WHEN THE TEMP IS VERY LOW IN THE FREEZER AND YOU LET WARM AIR IN BY OPENING THE DOOR. WHEN THE DOOR IS CLOSED, THE WARM AIR IS COOLED CAUSING A VACUUM IN THE FREEZER. IF THE DOOR SEAL HAS A LEAK AROUND IT, THE SUCKING SOUND WILL NOT TAKE PLACE. CHECK THE DOOR SEAL FOR A GAP AT ONE OF THE CORNERS OR ALONG THE SIDES,BACK, BOTTOM, OR TOP.IF THE SEAL IS O.K., HOW IS THE TEMP? IF THE TEMP SEEMS WARM, YOU MAY NEED TO CHECK THE SEALED SYSTEM. LOOK AT THE FROST PATTERN ON THE EVAPORATOR. IS IT COMPLETE AND UNIFORM? IS ONLY PART OF THE EVAPORATOR FROSTED BACK? IF THE ENTIRE EVAPORATOR IS FROSTED BACK UNIFORMLY, THE SEALED SYSTEM IS O.K.
Apr 01, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
You should check the drain hose inside underneath the freezer.This is done at the back down below. Mine was looped too high and water could not get out. I took the loop off that was holding the hose and now water can drain away without freezing. You can pour warm water down the drain hole to melt the ice in the tube if you remove the grate covering it inside the freezer. I have read that several Kenmore upright freezer
owners have the same problem. I was astonished that this was the problem and I had put up with it for too long, defrosting the freezer every 2-3 months!.Give it a try!
Nov 27, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
50 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
