Question about Sony FD Trinitron WEGA KV-36HS420 36" TV
Tv won't turn on
My sony trinitron's indicator light blinks 7 times when i attempt to turn it on and then it shuts off. i'd like to know what parts to buy, how and if i can fix it! thanks
  • Sony Master
  • 8,457 Answers
Ur high voltage is dead,FBT,the flyback transformer is dead.The big block of plastic with a red wire with a cap to the CRT(tv tube).
Posted on Sep 28, 2009
Sony trnitron tv won't turn on. stand by light blinks. Any ideas?
watch the blinking light---if a specific sequence like 7 blinks a pause and repeated endlessly that is a error code. It will not point to a specific part but will indicate where the issue might be.
Dec 19, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Kv 32hs420 7 slow blinks form the led light sounds comes on but no picture shuts it self down then give me 7 fast blinks hhhhhheeeeelllppppp
The slow blinks are normal at startup. The quick seven blinks indicate that a problem was detected and the set is shutdown to prevent further damage. I'll look up your model later today and post the probable defective parts. Are you planning on attempting the repair yourself?
Dan
Mar 10, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron KV-40XBR800 wont turn on
30 YR SERVICE TECH.
YOUR UNIT IS EXPERIENCING A POWER SUPPLY FAILURE.(INTERNALLY)
TAKE TO A SONY AUTHORIZED SERVICER.
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony won't turn on (wega)
Ur high voltage is dead,FBT,flyback transformer is dead.The big block of plastic with a red wire with a cap hook to the CRT(tv tube).
Jan 10, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
SONY WEGA KV-36HS420 will not come on
The blinking is an indication that the set detected a problem. The code usually indicates a bad regulator circuit. If yu can solder, you can probably fix this your self. Please let me know if you wish to attempt the repair. If not, expect a parts cost in the $25-$40 range plus the local labor rate for the repair.
Oct 01, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony Wega Trinitron KV-32HS20 TV
The 4 blinks usually indicate a vertical problem. If you can solder, you can fix this yourself. Let me know if you wish to attempt this repair. If not, expect a parts cost of $10-$15 plus the local labor rate for the repair.
Dan
Oct 01, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TV will not come on.
The 7 blinks indicate a high voltage shutdown (high voltage exceeded 33,000V). This is usually caused by a defective regulator. Could you please post the exact model number (KVxxx) and I'll look up the part you will likely need?
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA KV-36HS420 36" TV Logo
217 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
