Question about Pioneer Vsx-822-k 5.1-channel 3d-ready Network A/v Home Theater Receiver
Vsx-822-k no blu-ray signal
Vsx-822-k home theater hooked to tv and blu-ray with hdmi cables. Control and ARC are set to ON and on the TV, CEC and system audio control settings are ON. TV sound comes through the receiver speakers, however, when blu-ray input is selected, the blu-ray unit is on and the hdmi input is selected, the tv says that there is "no signal". I've verified that the cables are properly connected and fully inserted.
  • Dave Lamb
    Dave Lamb Dec 11, 2012
    Initially, both HDMI cables tested fine when direct connected from blu-ray to TV, but eventually I determined that one of the cables was failing and finally stopped working entirely. I changed the cable and all is good now.
Did you ever fix this?
Posted on Dec 11, 2012
  • holy_shnit
    holy_shnit Dec 11, 2012
    thanks, I believe this was my problem as well
3 Suggested Answers
  • 6 Answers
SOURCE: I just bought a vsx-1019ah receiver. I connected
Check if your KuroLink is on or off. There are a lot of problems that users have been having with the KuroLink on. Since you have a Pioneer display, KuroLink might help in switching both the receiver and the display on and off together, but my advice to you would be play around with the settings (in your case, especially KuroLink). Also remember, the KuroLink is on by default i.e. if you've never changed this setting, it probably is on.
Hope this solution works, else check out the Official Thread on Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Posted on Dec 07, 2009
SOURCE: Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Posted on Dec 10, 2009
How do I hook up my HDMI Blu ray player to my theater system that doesnt have HDMI
You have a few options depending on the entire system.
Do you have the TV audio output connected to the home theater system? In that case, connect the Blu-ray player to an HDMI input on the TV. Then leave the home theater system set to the TV input, while the TV is set to the HDMI input for the Blu-ray player. This is the simplest method.
You could use an audio extractor/converter. Here's an example: https://www.amazon.com/J-Tech-Digital-Premium-Extractor-Converter/dp/B00BIQER0E . This will let you send the video signal to the TV (with a second HDMI cable) and have digital or analog audio sent to the home theater system.
If the TV doesn't have an available HDMI port and the home theater system only has analog audio inputs, you could use an HDMI to component video converter. You'd use something like this: https://www.bhphotovideo.com/c/product/770115-REG/KanexPro_HDRGBRL_HDMI_to_Component_Converter.html . (Do not use an HDMI to component cable. Those only work with some projectors.)
I hope this helps. Please add a comment with more details about your TV and audio system for more specific information.
Feb 14, 2017 | Samsung Audio Players & Recorders
Why doesn't the ARC TV sound work through the HDMI cable? Is it because the KDL-52XBR7 only has the Bravia Sync and no ARC support?
Not all Hdmi cables have same capabilities. Check out:
http://www.hdmi.org/consumer/finding_right_cable.aspx
Mar 27, 2015 | home Audio Players & Recorders
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
Yamaha purple screen rx-v373
I had this same issue. I think I finally resolved the issue by turning off HDMI Control (HDMI-CEC) on my Blu-Ray player. I had the Blu-Ray player plugged into a Yamaha RX-V375 (almost an identical receiver). I think the source of the issue was that my TV does not not support HDMI-CEC. Turning off HDMI-CEC on the Blu-Ray player fixed the issue. The Yamaha receiver already had HDMI Control disabled, and all the other HDMI devices appeared to have HDMI-CEC disabled or not supported.
In my case, the symptoms of the issue were that I would see the correct picture for a second on power up, then the picture would go away. For the Blu-Ray HDMI input selected on the receiver, I would see a solid purple screen and a blank screen for the rest of the inputs. Sometimes switching inputs fixed the issue, sometimes power cycling would fix it, but it was getting very annoying.
Dec 03, 2012 | Yamaha Audio Players & Recorders
I have the btt350 home theater system connected by a hdmi cable from blu ray player connected to a panasonic 50" plasma 3d tv when playing a disc or listening to the radio from the blu ray player the...
Page 22 in the Manual details the required input to be selected dependent on the connection type.
To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
[OK].
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
connection.
Whenever the connection or settings are changed, reconfirm
the points above.
Please leave feedback
Cheers
Andy
Apr 26, 2011 | Panasonic SCBTT350 Theater System
I have hooked up my br to an onkyo home theater through hdmi. i now get an unusable signal on my flat screen. This also happens when I hook it up directly to the tv. What can I do to get this to work
hi,
The Blu-ray player outputs full HD VIDEO (1080p) through HDMI, if your tv is not a full HD one then you can't see the video. Do one thing connect the Blu-ray player to any full HD tv and go to it video setting. Down scale the video to 1080i. All HD ready tvs supports only resolution up to 1080i. only full HD tvs supports 1080p. Down scale the video to 1080i surely you will get video. Also check the version of HDMI cable you have used. It should be 1.2 or above.
ok
Feb 15, 2011 | Sony BDPS570 Bluray 3D Player
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
When i hook up my Bell 4100 Sat receiver to the Aux 1 in, i receive the sound but no video. I have tried using all sorts of combos, s-video and yellow video cable. The tv is hooked up witrh HDMI from the...
Thanks for clarifying that for me. The simple answer is the Denon home theater isn't able to convert the signal from your Bell receiver into an HDMI compatible format. You'll need to use either S-Video or the regular yellow cable to connect your Home theater to the television. The HDMI out provided would only work for the internal DVD player. This is a limitation of HDMI, not a problem with your home theater. You need HDMI in (or DVI in) to get HDMI out.
May 02, 2010 | Denon S-301
I can't get the sound to bypass the tv's speakers to my network blu-ray home theater system.
Are you hooking the TV to the Blu-Ray HTS with the HDMI cable¿ I have a client that had the HDMI cable from the HTS to the TV and needed to purchase an "Optical Cable" to get the sound from the TV to the HTS when they were using the cable box as the input. I hope this helps you going into the right direction.
Sep 19, 2009 | LG LHB953 Theater System
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Pioneer Vsx-822-k 5.1-channel 3d-ready Network A/v Home Theater Receiver Logo
253 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
