Question about 5900 SST 2-Way Security System / Remote Start System with Responder S
My viper 5900 makes 3 chirps when i try to disarm.And the only icon on the remote that flashes is the
I usually just hit the disarm button then hit the disarm button again to pop the doors,now it only make 3 chirps and does nothing,the little "signal indicator" icon flashes on the remote while doing this?
Megaduty
SOURCE: VIPER 5701 remote how tofix?
you have the key pad lock turned on. It protects the keys from unwanted pressing when in your pocket. To unlock you hit the F key then the unlock key, you can now use any command untill you let it set for 60 seconds, then it locks again.
to stop this totally, u hold down the F key for 12 seconds it will beep and top light turns orange, then hold down the unlock key for 2 seconds, it beeps then u hit the lock key to turn off this feature (top green light goes out). then hold F down, and F down again, should b good to go!
REM
Posted on Jul 14, 2009
SOURCE: my viper 2 way pager remote will not arm or disarm
It could be set on car #2. Press function for 8 seconds and a light next to lock should come on. If the light next to unlock and lock (two lights) then it is set to #2 car (you can operate 2 cars with one remote). All you have to do is press function again to toggle between the two cars. You want to end up with only one light showing.
So, hold function for 8 seconds, then after a light shows, release and press function until you only see the one light.
Posted on Aug 19, 2009
SOURCE: need to disarm the alarm because the remote is not
i have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
Posted on Oct 10, 2009
  • 132 Answers
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Posted on Apr 04, 2010
logosc75
  • 625 Answers
SOURCE: my remote starter for my viper 5900 2 way trans
Try reprogramming the remote. Open the door, turn ignition on, press and release valet switch one time, then press and hold valet switch while pressing lock button on remote.You should hear a confirmation chirp from the alarm. Release both buttons.Turn off ignition. test.
Posted on Oct 03, 2010
I have a viper 5900 car alarm with the 7701 vpx remote and the lock and unlock are reversed. How do I fix this
according to Viper tech support (I emailed them your question):
Thank you for contacting Directed support!
You may need to reprogram the remote to your phone. Please use the following instructions to reprogram the remote:
To program the remote to your system please do the following:
1) open the driver door
2) turn the key to the "on" or "run" position
3) locate the valet switch (small black button under driver side of dash) and press once, release, then press again and hold
4) after the siren chirps one time press the lock button on the remote
5) the alarm will give you a unique confirmation tone
6) turn the key off (the same unique tone will be heard again)
Warm regards,
Nigel McGee I Customer Service Rep.
Viper Support
Apr 28, 2016 | Viper Vehicle Parts & Accessories
My security system will not respond to the key fob commands.
Possibly change the remote battery? Get thee to a mechanic
Jan 30, 2014 | Viper Vehicle Parts & Accessories
How to program a remote control viper 5900 for a chevy Tahoe
Should be a switch for overriding the alarm under the drivers side dash. Two wires going to it (grey black) with a push button on the end if it. Have the driver door open and turn the ignition to on not running,,,, push the valet button and let go and then push and hold valet button........ Hit lock on the transmitter one time while still holding the valet button down. You should get a chirp for entering program and then when you lock on the remote it will make another chirp. But the chirp will sound awkward. Let go of valet and and turn truck off. And test remote. If that's doesn't work you may need to follow all the same steps but instead if press once and press and hold you will need to push 8 times and hold on the 9th and hit lock on the remote. I'm pretty sure the it's sequence is for alarm security and 8 steps is for remote start only models. Food for though if my mind is working backwards. Best off luck. All else fails I'm sure a shop will do for about 20$
Oct 28, 2013 | 5900 SST 2-Way Security System / Remote...
Hi. I have a Viper 5701 alarm in my car. Arm and disarm goes very well with the control unit. But I cannot programming to pasive arming, always have to use de button in remote control to works. Is ther a...
Open door, turn ignition on then off. Press aand hold programming button until you hear one chirp. After you hear the chirp, release programming button, press and release button one then press and hold. You will hear one chirp. While holding the programming button, press lock button on remote to change option. One chirp is active arming(what you currently have), Two chirps is passive arming without locks, Three chirps is passive arming with locks. Turn ignition on to exit programming. Test system.
Jun 13, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My remote starter for my viper 5900 2 way trans isnt working...my battery went dead in the remote, than after i replaced it, it's not working properly
Oct 03, 2010 | 5900 SST 2-Way Security System / Remote...
How can i program a new remote?
usually viper systems just need program button and ignition key. start by turning key to run then press the program button once then press again and hold. then press lock button of transmitter you want to add, parking lights should flash and then indicating that it is programmed. let go of switch and turn key off. try remote. good luck
Oct 09, 2009 | 5900 SST 2-Way Security System / Remote...
Viper 5900 remote start does not show it is off on the remote.
try a couple of things, 1) try unplugging the anntena for the alarm for about 5 minutes. 2) remove battery from remote for 5 minutes 3) reprogram the remote
May 21, 2009 | 5900 SST 2-Way Security System / Remote...
My Mustang Cobra has a Viper alarm system that won't set
Under the dash, Your installer that worked on your Cobra should have put an valet button under the dash, It is a small round Black button, Ok with the driver door open,,put your key in the ignition and go to the on position, Locate the black button before you do this, once the ignition is on hold the black button down for 3 seconds hit it once more and then turn the ignition off, the light should start flashing again and the chirp for arm and disarm with work again, What you have going on is called Valet mode which is designed to put the alarm side of the system to sleep which can happen from accidentally bumping it.
Hope this was helpful.
That Crazy Install Guy.
Apr 05, 2009 | Vehicle Parts & Accessories
Viper won't remote start and arm/disarm only works sometimes
Greetings Microluv,
Simple question, have you changed the battery in your remote lately? I was having similiar issues with my remote start and it was a simple matter of changing the batteries in the remote.
I figured lets eliminate the easy stuff first. :)
Dorothy
Go Ahead. Use Us.
Jul 07, 2008 | Viper RCVGC022 Remote Control
5900 SST 2-Way Security System / Remote Start System with Responder S Logo
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
