Question about HP G60-120US Laptop
Why will the battery not charge?
The battery will not charge even though it gets plugged in regularly. Does this laptop need new battery - cost of new battery vs new laptop
    Novelist:
    Champion:
  • 233 Answers
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Posted on Nov 28, 2012
  • HP Master
  • 2,072 Answers
New battery is around $100. You may have a DC jack on the laptop itself or even a faulty AC brick.
Posted on Nov 27, 2012
  • 2567 Answers
SOURCE: HP G60 laptop will not
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Oct 12, 2010
Testimonial: "Very detailed reply thank you. I know where to start now."
c-tekk
  • 177 Answers
SOURCE: battery not charging
Your Battery is Done.
Get a New One!
(it might be cheap or free if you are still under warranty.....so check up on that, but I'm not sure)
But your battery is dead, It has seen better days.
Posted on Apr 21, 2009
haayz
  • 197 Answers
SOURCE: HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
If you charged up your battery up for 2hrs but didnt increase the percentage or didn't charge up at all it means that your battery is faulty. I have also a same case with you.
Send it to the service center near you and ask them to rplace your battery. Replacement is free if machine is under warrant.y
Posted on Jun 03, 2009
SOURCE: Laptop intermittently charges / works
Seems the power board is defective, you need to take this laptop to a service center to check for a new power board or if diy check ebay, you can find a good one there.
Posted on Jul 08, 2009
inadeem
  • 38 Answers
SOURCE: laptopbattery is not charging even after repacing with newbattery
Please change you laptop charging holder most the laptop charging holders are not reliable in terms of rough use.
Or check your control penal settings for charging option.
Posted on Jul 27, 2009
Batery won't charge new battery n plug
You may have the wrong AC adaptor, Dell is very picky when it comes to Power adaptors, it must be original OEM Dell for the laptop to recognize it, any after market no name brand even though it has the right specs and is made for your model will power your laptop but the circuit to charge your battery will automatically be closed
Nov 17, 2012 | Dell Studio 1737 Laptop
When i pull out the power cord on my N150 plus the comp crashes,even though the battery is saying 100 per cent..any idea?
A lot of times this happens when the battery has gone bad and needs to be replaced. It might say 100%, but due to use (and sometimes just due to a faulty battery) the battery will charge less and less and eventually won't hold a charge at all. For example, when I first got my laptop a year and a half ago, I could get almost six hours out of a charge. Now I get almost twenty minutes. Unfortunately, I would say you need a battery. You can get one either from samsung (though you may have to call them, I couldn't find your battery on the site), Newegg.com, or ebay.com.
Some good tips for handling your new battery. First, if the computer's plugged in, remove the battery. Put it back in before you unplug it. This will prevent long-term wear on your battery. Secondly, it's good to regularly (I'd say yearly or so) let your computer "die" on battery (run it until the battery dies), then charge it completely THREE TIMES. This will "cycle" your battery. They say that with the newer batteries used nowadays this isn't an issue, because the new type of battery doesn't create the crystals like the older type does, but it can't hurt anything and I've noticed a difference when I do it.
I'm sorry about the bad news, but hopefully this will help!
Aug 22, 2011 | Samsung N150 (36725723009) Netbook
Hi. Our Advent Roma 2000 laptop seems to have a problem charging. Thought at first it was the charger so bought a new one, but still the same. The charging light flickers on and off as though there is a...
If you wiggle the connection to the laptop and it feels a bit loose, then the power connection on the laptop itself probably needs re-soldering. This is a common problem with laptops. Unfortunately unless you can do it yourself or know someone you can, then it will cost quite a bit to get fixed outside of warranty.
Feb 28, 2011 | Computers & Internet
I have compaq presario cq50, for the last little while it will say plugged in not charging, the battery was going, i replaced the battery, now once the battery is charged, it overheats, if i unplug the...
Sounds like a bad charging board connection problem and needs to be replaced.The cost depends on the cost of the board and if the person repairing it is like most computer repair shops it won't be cheap by no means.That is if they are straight up and don't try to convince you to replace the whole motherboard.They love to charge for a motherboard replacement when its what connected to it causing problems.
Jan 26, 2011 | Compaq Computers & Internet
Laptop won't charge
You might need a new battery....you could try removing the battery, plug laptop into ac and restarting. Or you might need a new DC power jack. If you wiggle the cord where it plugs into the laptop, and it starts to charge normally, then the DC power jack needs replacing. http://www.insidemylaptop.com/take-apart-sony-vaio-vgn-s360p-replace-broken-power-jack/
Apr 26, 2010 | Sony VAIO Notebook
My laptop won't turn on even though it's plugged into the recharg
Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone.
Laptops should be run on battery alone as much as possible, or the battery dies.
Apr 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
Power adapter isn't charging the battery when plugged in. Comp also won't stay on since the battery isn't charged and the power adapter isn't being recognized, even though it's plugged in. What do I do?
You need a new power cord. Walmart has a Universal one for about $78. This also happened to my laptop last week and I had to get a new one because it was shorting out. Even had sparks...
Jan 26, 2010 | Gateway 450SX4 Notebook
Inspiron E1505 - ac power not always on when plugged in outlet
I've had both the battery and the cord die in my old Dell laptop. Assuming it's like mine and the light is on while the battery's charging and turns off when the it's full....
Dell batteries don't last more than a year or two, so my first question would be how old is the battery you are currently using? When a battery is dying, it essentially isn't able to use its full capacity. So in addition to lasting less than an hour or so, it will try to charge for 6-12 hours trying to get a full charge even though it can't. So the light will stay on until it gives up. It will start charging again if you unplug it and plug it in again. If this is the case, you can either replace the battery ($100+ bucks) or ignore it and don't use the battery.
If the power cord is going, it will only work at certain angles. Play around with wiggling and bending the cord (not TOO far though!!) to see if you can get the battery light to shut off when you move the cord in a certain direction. A new power cord/adapter will cost you around $50 I think, if that's the problem. Let me know if your problem doesn't seem like either of these.
Hope this helps and best of luck!
Jun 18, 2009 | Dell Inspiron E1505 Notebook
Dell Laptop Won't Boot Up
Don't take this as a definate answer, as I am only going on from what I've seen close friends do though I don't remove my Battery from my Laptop even though.
I do have some Electronic sexperience though very limited so my answer is You don't need a battery for a Laptop to boot and it doesn't matter if it doesn't hold a charge anymore,
Your problem I suspect is something else, meaning without proper (enough) input regarding what the Laptop does and or doesn't do, eg. starts the P.O.S.T then stops, 3 beeps or 1 , possibly none. Can you get into the BIOS setup? Maybe Windows starts loading and stops somewhere in the boot process.
If you need anymore assisatnce then feel free to ask.
Apr 09, 2009 | Computers & Internet
BATTERY is charged, but will not work without being plugged in
Your battery is old and worn out, even though it indicates as fully charged. The battery capacity is practically zero. Rechargeable batteries have a finite number of charge and discharge cycles.
You need to buy a new battery if you wish to use the laptop without connecting to the mains.
Dec 01, 2008 | HP Compaq Evo n610c Notebook
HP G60-120US Laptop Logo
165 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
