Question about Generac Power Systems Generac 0057890 3250 Watt Gasoline Generator
I have a 3250 king Craft generator that won't start. The pully works ok but the pully connection will not turn.If you turn it backwords then try to start it the pully will work 3 times then it is bound up. I have checked the oil and the plug. There is about 30 running hours on it. The company will not help me. Has anyone else had this trouble? I just bought this last year. If anyone can help me please e-mail me at rlsmith3@msn.com Thank you
2 Suggested Answers
  • 1388 Answers
SOURCE: I have a 3250 watt Kingcraft generator that won't
Always troubleshoot with new sparkplug. Remove the oil sending unit connection from the coil. The coil should work without any wires connected. Usually the only connections are oil sending unit that will short to ground when low oil condition and other wire must be kill wire to on/off switch. Use carb cleaner spray directly into the carb with air filter removed and choke off as fuel supply. Just a short spray and another short spray after a couple of pulls. If engine wants to start you will need to keep spraying cleaner for engine to continue to run. If engine wants to run, replace fuel with couple gallons of premium fuel to get it going. Hotter fuel will help if the compression is low. Good luck
Posted on Aug 24, 2011
King Craft 3250 starts,but won't stay running?
It is probably a fuel related issue. It's most likely not ignition related because it starts and runs for a bit.
Clean the carb, make sure gas gets to the carb. Give it another try.
Jan 13, 2018 | Coleman Electrical Supplies
I have a kings craft and it want start it is the 1705 and I've had it for 3yrs andused it 1 time help me.
What would you like to know?
Fill oil to the top, add unleaded fuel, and pull the recoil to turn over engine 3 times. This should prime the carb. Then start!
If it is still not starting, please contact us. We are always happy to talk you through it.
https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
Jan 05, 2017 | Electrical Supplies
King craft 1705 generator produces no power out put
May have condinsation around the winding inside. Shut it off, try again (may have been a fluke)
Jun 17, 2016 | Electrical Supplies
Why is king craft 2200 generator govonor not working
Are you talking about idle switch or the primary running speed. Had the Gen. been stored for awhile. Check for free movement of linkages to Carburetor.
Aug 21, 2014 | Electrical Supplies
Low oil sensor
I would let it cool completely and see if it starts again. There are no specific timers that say after detecting a low oil shutdown don't start for X amount of time. It is more than likely a choke setting as it is hot, and you may now have flooded it.
May 11, 2013 | Powermate Portable Generator: 3250-Watt...
Onan 5500 marque gold turns over but, won't start. fault code is 32 but, batteries ok, air cleaner ok, fuel pumping, oil changed, won't start
Code 32 is a low cranking speed sense. You didn't mention a Spec # which would help. You say batteries are ok, but the generator is not getting enough cranking amps or voltage to maintain the control properly. Check, battery voltage, wiring, any in line isolation solenoids, check generator solenoid, also make sure there is no mechanical binding on the generator, a good way to do that is remove the spark plugs DISCONNECT THE BATTERY to prevent starting, underneath where the air intake is under the alternator is a plastic plug, remove that and you can put a socket I believe 3/4" up onto the alternator shaft and rotate the engine, if it tuns freely there is no binding, if you feel it is hard to move, check the drive train, belts, pulleys underneath (A lot of work, best to take to a dealer if it is mechanically bound)
Sep 13, 2012 | Onan Marquis Gold Quiet Gas Generator 5500...
Aug 24, 2011 | Generac Power Systems Generac 0057890 3250...
Generac Power Systems Generac 0057890 3250 Watt Gasoline Generator Logo
22 people viewed this question
Top Generac Power Systems Electrical Supplies Experts
John Trevino
richie46
Bill Boyd
Are you a Generac Power Systems Electrical Supply Expert? Answer questions, earn points and help others
