Question about Cobra FA-CG Micro Talk Walkie Talkies
What is the range of a Cobra FA-CG Micro talkie set?
Does anyone have any suggestions on were I could get a replacement manual for i?
Whats the voltage maximum on the cobra walkie talkies
Most lithium small radio batteries are 3.6 volts. If AA or AAA batteries, multiply by 1.5 volts. 4 batteries = 1.5 * 4 = 6 volts MAXIMUM. Rechargeable batteries are 1.2 volts. Your charger would be a much higher voltage because it takes power to "push" the charge into a battery. You didn't say, so I am assuming you want to operate the radio with a wall charger. I've done this by soldering the wires to the battery contacts. You need a higher voltage than 3.6 volts, but milliamps is more important. You need enough milli amps to get the radio to transmit. Too much and it frys, literally. So, this is all on you to decide if the risk is worth it. I use a 5-6 volt power supply set on no more than 1 amp (800 ma is my favorite size) 1 amp = 1000 ma. Let us know if this helped!
May 20, 2016 | Cobra FA-CG Micro Talk Walkie Talkies
Can I do morris code on this model?
Well, any radio could do Morris Code. The question really is how. Handheld radios would need to be hooked up to an input device to take the place of a Morris Code "key". The person listening needs to hear the dit, dit, dit, dash, dash noises. I am not certain if that is what you want from an FRS radio. It would take some cobbling together. What is your goal?
Jan 07, 2016 | Cobra FA-CG Micro Talk Walkie Talkies
Do you leav the cobra micro talk walkie talkies on when charging
Also, never transmit with them in the charging cradle. I know, lots do but you risk ruining the radio beyond repair.
Dec 26, 2014 | Cobra LI6050-2WXEVP microTALK 22 Channel...
One will not charge How to change batteries
There's a small half-round clip at the bottom, open that, then you are able to lift the battery cover and swap batteries.
Apr 10, 2014 | Cobra FA-CG Micro Talk Walkie Talkies
Walkie talkie radio sku #641068 lost charger
  • Hope this helps.
Oct 28, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
Have Cobra Micro Talk Walkie Talkies and have lost the instruction manual and do not remember how to program them
This was extremely difficult to find but I have located the manual for you on these walkie talkies. It will be easiest to just use the manual and follow the instructions. If you still have questions or problems please respond here and I will get back to you. Please rate my answer 4 thumbs up here on the site, it is very important to me. I would be forever grateful. Here is the manual:
http://www.cobra.com/downloads/manuals/PR4000WX_manual.pdf
Oct 12, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Cobra FA-CG Micro Talk Walkie Talkies Logo
319 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
