Question about Casio FX-115ES Scientific Calculator
My casio fx-115 es calculator is set to radians, but is not giving me an answer in terms of pi...It was but I guess I bumped something to change that, I need it back to normal please help!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Press SHIFT MODE 1 to switch to MathIO mode.
Posted on Nov 27, 2012
  • kakima Nov 27, 2012
  • 7993 Answers
SOURCE: How do you switch between degree and radian mode
Press SHIFT MODE to access (SETUP)
Press 3:deg for degree OR
press 4:Rad for radian.
Posted on Apr 05, 2010
  • 7993 Answers
SOURCE: Casio FX-115 ES: SIN,COS,TAN (answer isnt correct)
It may be due to the angle unit used. You can have angles in degrees, in radians, and in grads. You should set the default angle unit to waht you problem calls for.
To set degree as default SHIFT MODE 3
To set radians as default SHIFT MODE 4
To set grads as default SHIFT MODE 5
The values of angles calculated by the inverse trigonometric functions are in the default unit that is set . This may be the source of the wrong answers that you get.
Hope it helps.
Posted on Sep 17, 2009
Testimonial: "thanks alot!! "
  • 7993 Answers
SOURCE: sin, cos, or tan, on casio wrong answer. another cac right answer
Hope it helps.
  • 7993 Answers
SOURCE: Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Posted on Oct 02, 2009
Testimonial: "Thanks so much, its working now:) I thought I was going to have to buy a new calculator!"
  • 7993 Answers
SOURCE: how the heck do you change a casio fx-9750II from radian to degre
  1. With calculator turned on, press [MENU] if you do not see icons.
  2. Use the navigation arrows to highlight [RUN-MAT] icon or press 1.
  3. In the Run-Mat screen press [SHIFT][MENU] to enter the (SETUP).
  4. Press the DownArrow 5 times to highlight the ANGLE option.
  5. Press [F1:Deg] to select degree.
  6. Press [SHIFT][EXIT] to (QUIT) the SetUp screen.
  7. Do your geometry ( I would say trigonometry).
Posted on Apr 08, 2010
Bought a Casio FX-260 calculator. Im trying to find out how to input a trig formula. E.g 2/cos(70)= 5.84 When I do put this in the calculator in scientific mode it gives me a different answer. Help?
I'm guessing that your calculator is set to radians or gradians (or degrees, if you are looking for a result in radians or gradians).
Try changing this and hopefully it will work.
Otherwise, post again!
Good luck,
Paul
Jul 25, 2016 | Casio Office Equipment & Supplies
How can you find the circumference of a circle using the FX-ES 115 Plus?
Th formula is PI *dia.
Pi is available on this model using Shift key + X10 key at middle bottom.
So enter Pi then key x (multiply) then enter diameter then = key.
http://support.casio.com/storage/en/manual/pdf/EN/004/fx-115_991ES_PLUS_C_EN.pdf
Nov 10, 2014 | Office Equipment & Supplies
Is it possible to solve eqn in this 82ms calculator
Sorry, It is not possible to solve equations on the Casio FX-82 ms. Try the Casio FX-115 ES/ FX-115 ES Plus, FX-991ES/ FX-881 ES Plus C.
Oct 29, 2013 | Casio FX82MS Scientific Calculator
When I type sin(60) into my fx-115 ES calculator I get the answer 0.8090169944 how do I change it so that it will give me a number that could be found on the unit circle?
Your calculator's angle unit is set to grads. In that unit, the value of cosine 60 is correct. You might want to change the unit to degree to get a more orthodox result.
Press SHIFT MODE to access (Setup) and select degree or radians as angle units.
As to a `number that could be found on the unit circle``, I admit I do not understand what you mean because the sine is the measure of a segment that lies along the y-axis and not on the unit circle. If you care to clarify what you want, I may be able to help.
Jun 04, 2011 | Casio FX-115ES Scientific Calculator
I think i accidentally pressed something and my calculator is all messed up, for example cos, sin , pie... are not giving me accurate - correct answers. I'm sure something is wrong with the settings, any...
I don't see how the value of pi may be incorrect. It is given by the calculator with a certain precision, dependent on the number of decimal digits you accept in the display.
As to the trigonometric functions, the values returned depend on the angle unit you are using. Have you changed the angle unit from degree to radian?
Press the [DRG] key to cycle through the 3 angle unit until you find the one you are familiar with.
Aug 13, 2010 | Casio FX-300MS Calculator
How do you switch between degree and radian mode on the fx-115 ES Casio calulator? Thanx
Apr 02, 2010 | Casio FX-115ES Scientific Calculator
Hope it helps.
Sep 16, 2009 | Casio FX-115ES Scientific Calculator
Sin, cos, or tan, on casio wrong answer. another cac right answer
Hope it helps.
Inputing factors on a casio fx-115es calculator
Unless I am failing to understand your problem, just combine like terms to get:
9x^2+2x+4 and then enter those coefficients into the quadratic solver.
That will get you the two answers -- both of them will be complex.
If you wanted to turn those two answers into factors (complex) of the original equation simply
change the signs on each and put an x in front.
Of course, the quadratic formula would also work.
CG
Apr 17, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
384 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
