Question about Generac Power Systems Generac 0057890 3250 Watt Gasoline Generator
I have a 3250 king Craft generator that won't start. The pully works ok but the pully connection will not turn.If you turn it backwords then try to start it the pully will work 3 times then it is
2 Suggested Answers
  • 1388 Answers
SOURCE: I have a 3250 watt Kingcraft generator that won't
Always troubleshoot with new sparkplug. Remove the oil sending unit connection from the coil. The coil should work without any wires connected. Usually the only connections are oil sending unit that will short to ground when low oil condition and other wire must be kill wire to on/off switch. Use carb cleaner spray directly into the carb with air filter removed and choke off as fuel supply. Just a short spray and another short spray after a couple of pulls. If engine wants to start you will need to keep spraying cleaner for engine to continue to run. If engine wants to run, replace fuel with couple gallons of premium fuel to get it going. Hotter fuel will help if the compression is low. Good luck
Posted on Aug 24, 2011
I have a kings craft and it want start it is the 1705 and I've had it for 3yrs andused it 1 time help me.
What would you like to know?
Fill oil to the top, add unleaded fuel, and pull the recoil to turn over engine 3 times. This should prime the carb. Then start!
If it is still not starting, please contact us. We are always happy to talk you through it.
https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
Jan 05, 2017 | Electrical Supplies
King craft 1705 generator produces no power out put
May have condinsation around the winding inside. Shut it off, try again (may have been a fluke)
Jun 17, 2016 | Electrical Supplies
Why is king craft 2200 generator govonor not working
Are you talking about idle switch or the primary running speed. Had the Gen. been stored for awhile. Check for free movement of linkages to Carburetor.
Aug 21, 2014 | Electrical Supplies
Low oil sensor
I would let it cool completely and see if it starts again. There are no specific timers that say after detecting a low oil shutdown don't start for X amount of time. It is more than likely a choke setting as it is hot, and you may now have flooded it.
May 11, 2013 | Powermate Portable Generator: 3250-Watt...
Onan 5500 marque gold turns over but, won't start. fault code is 32 but, batteries ok, air cleaner ok, fuel pumping, oil changed, won't start
Code 32 is a low cranking speed sense. You didn't mention a Spec # which would help. You say batteries are ok, but the generator is not getting enough cranking amps or voltage to maintain the control properly. Check, battery voltage, wiring, any in line isolation solenoids, check generator solenoid, also make sure there is no mechanical binding on the generator, a good way to do that is remove the spark plugs DISCONNECT THE BATTERY to prevent starting, underneath where the air intake is under the alternator is a plastic plug, remove that and you can put a socket I believe 3/4" up onto the alternator shaft and rotate the engine, if it tuns freely there is no binding, if you feel it is hard to move, check the drive train, belts, pulleys underneath (A lot of work, best to take to a dealer if it is mechanically bound)
Sep 13, 2012 | Onan Marquis Gold Quiet Gas Generator 5500...
Aug 24, 2011 | Generac Power Systems Generac 0057890 3250...
I have a 2007 road king that was starting and running perfrectly. I stopped and it would not start. Acted like the battery was low.i checked with a vlot /ohm meter. It was good. I tried to jump it and it...
I have the same problem with my 2008 King. Have you run the on board diagnostics to see if there are fault codes stored? I am starting with the air filter. I took it off and started the bike and as usual it started Ok then I let it run and stopped the engine. Normally at this point it won't start first time but with the filter off it did, so I am changing that. If this doesn't work I will be looking at the Oxygen sensor in the exhaust system as this might be faulty. I had a 05 King before this one and the sensor moved when the throttle was moved but on this 08 model it doesn't and as it sits in the hot air of the exhaust and my starting problems only occur when the bike is hot, it might be that. I'll try the simple first in accordance with Ochims razer principle.
Jun 29, 2010 | 2008 Harley Davidson FLHRC Road King...
Generac Power Systems Generac 0057890 3250 Watt Gasoline Generator Logo
53 people viewed this question
Top Generac Power Systems Electrical Supplies Experts
John Trevino
scj103
richie46
Are you a Generac Power Systems Electrical Supply Expert? Answer questions, earn points and help others
