Question about Dell Latitude D810 Notebook
Right side of screen is black
Hinge loose
    Genius:
  • Dell Master
  • 2,432 Answers
You will need to remove the cover of your pc notebook, then look for the screen back light in the right side portion which may busted. you will noticed the back light get black color.
Posted on Nov 27, 2012
Hinge on right side is cracked. When it is
The right hand side hinge has the ribbon cable for the top screen inside and the 2 wires for ths mic and wireless, chances are the ribbon cable has become damaged, therefore the top screen will proberly need replacing.
Jan 18, 2010 | Nintendo DS Lite Console
Tip
How to repair Hinges on a HP ZV6000
<p>If a loose screen hinge screws <br /> <p>1. Turn off your computer and remove all components of the computer that sending an electrical current to the system, including power cables, peripherals and battery. <br /> <p><br /> <p>2. Close the display and turn off the computer base to cope with the hinge side of the computer to you. <br /> <p><br /> <p>3. Extract the four screws on the bottom border. <br /> <p><br /> <p>4. Remove the rubber plugs on the back of the hinges of the screen and the two screws underneath them. <br /> <p><br /> <p>5. Turn off the computer and open the screen, so they sit flat against your work. <br /> <p><br /> <p>6. Press the area marked on the right side of the keyboard cover (the plastic strip on the top of the keyboard) to it from the computer. Lift your right a little push and cover the central part of the keyboard to release it. Lift up the middle and let the left up to the keyboard cover for free from the computer. <br /> <p><br /> <p>7. Unzip, the four screws on the top of the keyboard and the keyboard on the fold of the palm rest with the buttons down. Disconnect the keyboard cable and remove the keyboard. <br /> <p><br /> <p>8. Loosen the two screws that secure each display hinge to the computer. <br /> <p><br /> <p>9. Attach the keyboard and the keyboard. Make sure all screws that secure each part to fix. <br /> <p><br /> <p>10. Place the screws on the back of the hinges of the screen and replace the rubber stopper. <br /> <p><br /> <p>11. Insert the battery, cables and components that you removed in step 1 to complete the process. <br /> <p><br /> <p>Broken so replace hinges <br /> <p>1. Turn off the computer and get rid of its power transmission components. <br /> <p><br /> <p>2. Turn off your computer and remove the four screws on the hinge side of the base of the keyboard. <br /> <p><br /> <p>3. Remove the rubber plugs on the back of each screen hinge, and pull the two screws in the hinges. <br /> <p><br /> <p>4. Unplug the computer and open the screen. Follow the instructions to step 6 of chapter 1 to the keyboard cover. <br /> <p><br /> <p>5. Remove the keyboard by following step 7 of Section 1 <br /> <p><br /> <p>6. Disconnect the cable from the connector on the computer screen right in the middle of the screen panel. <br /> <p><br /> <p>7. Disconnect and remove the two antenna cables from the mini-PCI wireless card in the middle left of the keyboard and cables in the guide, take it to the computer. <br /> <p><br /> <p>8. Unzip the two screws on each hinge and lift the computer screen. <br /> <p><br /> <p>9. Remove the six rubber pads on the front panel display, and remove the screws under them. <br /> <p><br /> <p>10. Remove the display. <br /> <p><br /> <p>11. Unzip the two screws on each screen, internal hinges and remove the hinges of the screen. <br /> <p><br /> <p>12. Follow the procedure in reverse, with hinges to the new computer installation. Make sure you remove all the screws, so everything is nice and tight as the computer is assembled. <br />
on Jun 22, 2011 | Computers & Internet
Laptop hinges are loose
The hinges can be loose in two different areas, but the most popular is the hinge attachment point behind the screen bezel. Remove the rubber screw covers from the bezel, remove the screws, take your finger nailas and from the inside of the bezel pull gently to the outside to release the catches on the screen lid. Start on one side and work your way around the screen until the bezel pops loose. Look at the bottom of the screen and you will see the hinge attachment points. Tighten them up. If you have some locktite this would be a good time to apply it, remove the screws one at a time and replace. To replace the bezel, always start at the bottom and work your way up.
Jan 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
I can only open lid half way and then screen blacks out
Most like ly the cables for the monitor are getting hung up on the hinges, when the lid opens, the hinges are pulling either the main video cable loose from the motherboard on the left side, or the inverter wiring is getting pulled free from the right side. Below is the service manual that will show you how to disassemble the laptop down to the point where you can inspect, reseat and free the hung up cables...or if some of the cables have been rubbed through, tape them up with electrical tape, heat shrink tubing or replace the cables with new ones.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00374392/c00374392.pdf
Nov 11, 2009 | HP Compaq nx9030 Notebook
Broken Inspiron 1525 Lid
hello
To fix your laptop follow the steps given below.
  • First of all as your hinges are broken you have to buy a pair of hinges for your laptop model.
  • This hinge includes the whole assembly made up of metal with a part which attaches your screen to the laptop.
  • Now you have to open up your laptop from the backside and disassemble the upper side.
  • This will make you see the part which detaches tour screen from the laptop.Just remove the screws and your screen will be completely detached.
  • now you can replace the damaged hinges with the new one.
  • you have to remove four screws for one hinge.Two screws supporting the screen and two attaches the screen with the laptop.
  • so remove these screws and replace the hinges and pack the laptop again.
And the lines are basically due to the movement of loose connector. So while fixing please fix the connector also.
Thank you
Aug 21, 2009 | Dell Inspiron 1525 Notebook
I dropped my ideapad u110 and have problems with the moniter
Hi shinehmoon,
For yourhinge issue, I recommend to contact the technical support of Lenovo. They willset up a depot repair for you to diagnose the computer and to repair itcompletely. You may contact them at this number 1-877-4Lenovo (1-877-453-6686).
--> Hours of operation, 24 hours a day 7 days a week.
Hope it helps,
Thank you for using FixYa.
Apr 04, 2009 | Lenovo IdeaPad U110 Notebook
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Toshiba Satellite 2450
It sounds like the hinge itself is broken. I have a relative with exactly the same problem, her laptop screen became floppy and didnt stay in the upright position. The hinges for the screen are complicated in that they appear to come as a top/bottom part already joined together, and need to be replaced as such. The metal used for the hinges is really flimy and easily snaps. this sounds like what has happened to yours. The problem is that is appears to be not econimcally viable to repair, and your probably better off scrapping it or buying another with say;.. a cracked screen and doing a swap-over of parts to get one fully working one (thats what I did)
Feb 25, 2008 | Toshiba Satellite 2450-401 Notebook
Aug 25, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Dell Latitude D810 Notebook Logo
37 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
