Question about Frigidaire GLGF376DQ Free-Standing Gas Range with Self Clean Oven, Bisque, 5.0 Cu. Ft. Self-Cleaning Deep Sump Oven with Auto-Latch Safety Lock, UltraSoft Backguard Design, Upswept Cooktop, Ultra-Style Cast Iron Grates & Caps, Electronic Ignition GLGF376-DQ GLG
Frigidaire Gas Self Cleaning Oven door open in lock position
My Frigidaire Gas Self Cleaning Oven door is open in lock position and panel is flashing "lock". I can't close the door. I've tried turning off the breaker box and then back on. I've also tried cancelling after holding the door/light button, which for some reason is not turning off the light either. Any advice?
  • ericndiana6b
    ericndiana6b Nov 27, 2012
    I've unscrewed the lock and now the door can shut, but it is still blinking "lock" and we can not cook or clean. When we try to program anything the "dr" comes on panel.
  • Official Brand Answer
  • 4,342 Answers
Hello ericndiana6b - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Posted on Dec 12, 2012
FFGF3047LS...how to remove maintop
there are screws in the back and then there are screws under the top on the front that are hidden by the oven door.
Jul 08, 2016 | Frigidaire Ffgf3047Ls 30" Gas Range W/4.2...
All 5 spark igniters not clicking
Could be range of problems including:
Power not connected/turned off
Ignitor ports clogged
Incorrect operation
Manual is available via Google
Aug 09, 2015 | Frigidaire Gallery FGGF3032MF 30"...
Prob light stays on, prob is not connected. Will not allow me to heat the oven to a proper temperature or to turn off. Tried unplugging. Frigidaire fggf3054
Press the probe button and hold for 6 seconds.
Press self clean and toggle until "continue" message appears.
Press start to accept.
good luck!
Nov 27, 2014 | Frigidaire Gallery FGGF3054M 30"...
Bosch gas range error code F11
Disconnect the ribbon from the control panel and clean it using pencil eraser. then carefully reconnect it.
If the F11 is still there most likely it's the control panel.
God bless you
Feb 01, 2013 | Bosch Evolution 500 HGS5053UC 30"...
Broiler shuts off
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
Jan 18, 2013 | Maytag Gemini MGT8655X 30" Freestanding...
Can i open (lift) the cooktop on a frigidaire ffgf3053ls gas range?
Hello Frank - Since a gas range is such a complex unit and for safety and liability reasons the unit is not designed to be lift open. However you may clean the burner grates, burner caps, and the surface burner heads.
Oct 02, 2012 | Frigidaire FFGF3053LS 30" Freestanding Gas...
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Frigidaire GLGF376DQ Free-Standing Gas Range with Self Clean Oven, Bisque, 5.0 Cu. Ft. Self-Cleaning Deep Sump Oven with Auto-Latch Safety Lock, UltraSoft Backguard Design, Upswept Cooktop, Ultra-Style Cast Iron Grates & Caps, Electronic Ignition GLGF376-DQ GLG Logo
168 people viewed this question
Top Frigidaire Irons Experts
Thomas Perkins
Thomas Perkins
Ken Wieczorek
Ken Wieczorek
Are you a Frigidaire Iron Expert? Answer questions, earn points and help others
