I am looking for AM-03 E181521 AC 120V 60Hz 3RPM CW/CCW motor
Outside reindeer that has a moving head
catriver
  • 878 Answers
SOURCE: removing tub
counter clockwise. Catriver
Posted on Sep 20, 2007
aasc
  • 1606 Answers
SOURCE: Which way does the spanner nut turn..CW or CCW?
CCW to remove , CW to tighten .
Posted on Sep 20, 2009
SOURCE: will not spin fast, only goes cw and ccw at medium
I took the stainless steel basket out and found the aluminum spider to be rotted. The basket was dragging and that made the motor overload.
I made up a stainless steel plate, took the original shaft and pressed it in.
Re-assembled and now is fine
Posted on Nov 15, 2009
rmac2001
  • 7 Answers
SOURCE: Won't spin after drain seems it has rough spot
Its the water pump- a shiney metal retainer is partially out and rubbing against its housing.
Posted on Mar 21, 2010
tattootech2
  • 72 Answers
SOURCE: will not spin during spin portion of cycles. it
It's either a bad door switch, or motor control board. Definitely easier and cheaper to try changint he door switch first, as it fails much more often. Part number is 131763202
Posted on Apr 07, 2010
Where can I buy: #AM-03 E181521 AC120V 60HZ 3.7 Z.P. 3RPM CW/CCW
e-bay or you local repair shop for what ever it is
Dec 29, 2016 | Garden
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
Dead AM-03 Motor
You may have to do some research to find another manufacturer of something similar. The motor powers an air pump so you may have to get an integrated unit as a replacement.
Nov 09, 2013 | Heating & Cooling
Hello. i would like to know the direction drive shaft spins looking from rear of bike cw ccw
If the drive shaft is on the right side of the bike it will spin counter clockwise (ccw) when the cycle is moving forward.
If the drive shaft is on the left side of the bike it will spin clockwise (cw) when the bike is moving forward.
Jan 26, 2011 | Honda VF 750 C Magna Motorcycles
. How do I wire this for forward and reverse use
you can reverse the rotation CCW to CW if you reverse the wiring on the brushes
Jan 09, 2011 | Dayton Universal Ac/Dc Open Motor 1 Hp...
The fan is not working, what should I do?
there two fans 1 inside the freezer and other down by the compressor . both are not hard to replace but do order it by model and ser # because there are ac and dc motors an cw and ccw motor. and they all look the same . some are 9 to 12 volts and 110 v . so do order the correct motor . for your model . if more help is needed need model & ser # of your unit .. mm feed back pls ..
Dec 11, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Goodman 3 ton outside unit fan not blowing
Motor, wiring and/or capacitor. If the sticker on the side of the motor isn't burned off you can get the motor info off that. Model numbers from the motor do little for locating the motor but my help. Best thing to do is get the AC motor specs and look up online (cheapest) or go to a motor shop. The specs you need would be as follows.
Horsepower-Such as 1/4 or 1/3
Voltage-Most likely 240/1 (240vac single phase)
Rotation-CW/CCW looking at the shaft end of the motor
Amps
Frame size
Jul 10, 2009 | Goodman CKL60AR60 Air Conditioner
Defective rotating grill motor
I have found the manufacturer of the motor in China and have ordered a replacement part.
Thanks,
Canadiano1
Jul 28, 2008 | Kitchen Appliances - Others
Washing Machines Logo
144 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
