Question about Samsung Cover Filter Ugrac Oem Original Part Dc63-01140a
Samsung dryer cover-filter tab broke, how do I change it?
The tab on this cover door broke. I have ordered a new one, and have received it. Seems easy enough to replace; a few screws that hold the housing, but... there's something holding it in. Now, how do I get the other parts out so I can install the new cover-filter? Thanks in advance. JC
I need to find out how to open the cover to change the motor filter on my Electrolux Epic Series 6500 sr canister vacuum.
There is not a replaceable motor filter inside the body of the vacuum. There is an exhaust filter under the cover on top which can be removed by pushing a little tab at the rear of the cover.
Nov 15, 2017 | Electrolux Vacuums
How to change the filter and wash
It you have the ball. Look on the side and you will see two small cut outs. Just screw it off and you will see the filter also there one on top of the The trash Collector. If you have the older model. Remove the trash collector and pop up the flat base under it. Wash the filters with warm water and let dry for 24 hours.
Apr 26, 2016 | Dyson DC07 Animal Bagless Upright Cyclonic...
How to get the filter cover off
There's a "tab" at the top rear of the vacuum that must be depressed while pulling up on the filter cover.
You can then access the filter for easy changing.
With 30 yrs. experience, I have a legitimate store front business and do service by mail at a reasonable cost if interested.
Hope that helps! Mick
Mar 07, 2015 | Electrolux Epic 6500 / 7000 legacy vacuum...
Why cant i keep my hepa filter and cover on my new navigator?? help?
Are you sure that you are correctly connecting the filter, and flipping the tabs to "lock" it into the "closed" position.
Jun 13, 2014 | Shark Navigator Bagless Upright Vacuum
The air flow indicator on my hoover elite rewind bagless vacuum shows mostly yellow. we have followed all the directions in the manual - empty dirt cup, cleaned filter, checked two locations for blockage,...
Hi, sounds like you may have a small leak in the vacuum body. After changing the filter etc. turn machine on and run your hands alond vac. body. If there is a leak you will feel or hear it. If leak is found the light should change when you cover it. I hope this helps you./ Its hard to give advice without seeing it. Give it a try then let me know how you are doing. Chris
Feb 09, 2011 | Hoover U5507900 Elite Rewind Bagless...
My rainbow e-series canister vacuum cleaner has a horrible smell. i cleaned out the water tray and it STILL smells horrible. how do i fix this problem?
Get a new hepa filter.
It is at the back side of it, behind that rectangular cover, where the exhaust cover is. It either snaps off with two plastic tabs on the bottom of it, or has two screws on the bottom of it, and two screws behind the cord holder taps thing. If it is that kind, the cord holder tabs thing, snaps off with a flat head screw driver on either side of it. You will see the little slots on it, if it is the kind with the screws on the filter cover. Two screws behind the cord holder tabs thing, towards the top of the filter cover, and two on the bottom of the filter cover.
Always clean your water separator with a tooth brush, or Rainbow separator cleaning brush. If it has it, it is by the water separator in a special slot for it, rite there by the water separator. If not, use a tooth brush. They are just alike. The separator nut, is a half inch, or 13 milimeter size of a nut.
Thank you,
Ralph
Nov 23, 2010 | Rainbow E series Canister Wet/Dry Vacuum
How do I install new filters on a Miele Blue Moon?
There are two filters on the blue moon. The hepa filter and the motor filter. You get to both filters the same way. You open the lid, like you do when you change a bag. The motor filter is right behind the bag inside a plastic cover. There should be two tabs you can pull down to open and access the filter. The hepa filter is located toward the back of the bag chamber but on top. There is one tab in the middle that lift up on.
Sep 23, 2009 | Miele Blue Moon Bagged Canister Vacuum
The back filter and cover blow off immed when vacuum turnd on
Has the cover got tabs that is suppose to catch when it's installed? check and see if there are broken plastic ends either on the vac or cover. It should be able to catch to hold it on.
Jan 31, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
No vacuum
Someone must have lost the filter cover from the machine. It is a clear blue plastic cover that goes over the filter and has a hole that lines up with the motor intake. It is approx. 3 inches square and has an angular top to coincide with the motor intake. Look around the house for it or order a new cover.
Jan 01, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Samsung Cover Filter Ugrac Oem Original Part Dc63-01140a Logo
65 people viewed this question
Top Samsung Vacuums Experts
woodzowl307
ray gallant
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
