Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
My Badger 5 in sink erator is leaking at the bottom of the unit where the electrical wire is connecting tot the metal plate. When turned on, there is a humming noise but the blades do not spin. I have
My Badger 5 in sink erator is leaking at the bottom of the unit where the electrical wire is connecting to the metal plate. When turned on, there is a humming noise but the blades do not spin. I have tried the broom stick trick and it does make the blades spin but once turned off, I have the same problem again. So basically, I have a leaky erator at the bottom with "push to start" blades, LOL! Any suggestions before I replace this unit?
    New Friend:
Thier is an Allen key hole at the very bottom and center of the badger. Try using that with an Allen key. And if it leaks your from where your wires are coming out of your seal is probably bad. Means new badger
Posted on Nov 27, 2012
My Badger 5 is just humming and I smell a bad burning smell.
Either the Shredding Plate or the motor has burned out. In your case, it sounds like the latter. The motor is not repairable, you have to buy a new unit complete.
Insinkerator Garbage Disposal Hums But Doesn Work
Insinkerator Garbage Disposer BADGER 5Troubleshooting Repair Help
Badger 5 Garbage Disposal InSinkErator
Dec 09, 2017 | Electrical Supplies
Badger 5 leaking from body middle connection
1) Copy following link for troubleshoot and parts resources, and manuals with warranty information:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
2) New unit would be best solution. And possibly cheapest solution. Otherwise you might be installing and un-installing more than once or twice ... which is fun if you have time, and other housemates don't mind kitchen project tools, water and mess.
3) If you can disassemble the disposal, you might be able to make your own gasket using kits and sealant from local auto parts .... assuming the metal was not mis-cast during manufacture and is warped so it never seals.
Dec 12, 2012 | In-Sink-Erator InSinkErator Badger 5 1/2...
I have the Badger 5 in sink erator under sink food disposer and it is leaking from a small on the bottom of the unit. How can I repair the unit?
Disposal is rusted out and needs to be replaced.
If you plug the hole, the motor compartment will fill with water and short out the electric.
I wrote ez replacement steps from when I worked apartment maintenance:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jul 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My sink erator badger 5 is leaking at the bottom, should I replace it or try and stop the the leaking.
mine was leaking from bottom, dripping off power cord...pulled it apart..the pan that separates the water and food from the electric motor was developing pin holes from corrosion...I dont know that you can get this part...was thinking about tacking a small weld...but best off getting a new one...I am sure it has served...
Jan 12, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking on bottom of disposal by wire connection
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Sep 09, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Water drippinp from the bottom of badger 5
Check all of your seals. Wipe your hand all the way around your disposal to check for moisture running down. Pay close attention to the areas where there are seals, like the top where the main gasket is located and the side where your drain connects there are rubber gaskets that can begin to leak. Also check where the dishwasher drain connects if applicable. If all gasketed areas are ruled out than unit itself may be leaking and need to be replaced. I hope this helps.
May 26, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
In sink erator is leaking from bottom
I had this happen right before my disposal stopped working completely. Mine was leaking from the same place. The one I had was a 2 year Badger. They are easy to replace. If yours still works I would keep using it and just sit a pan down below to catch water. A new Badger 1 year cost $80 at Home Depot. If you get one, do not worry about buying extra gaskets or the black sink strainer thing because the new one will come with everything needed except for the plumbers putty. You will need plumbers putty. Good Luck
Jul 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator leaking at bottom by electrical connection
I don't think it can be fixed by anyone other than the factory. I wanted to find a parts list so I could buy a seal that goes above the motor housing (which is where i think the problem really is) and repair it myself. I wish I had better news but since the leak is small and the motor still works, I'm going to keep a bucket beneath it and periodically empty it as recommended by a previous contributor.
May 31, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
601 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
