I need the flame sensor part number for a Carrier 58PAV090-14 furnace.
  • 2 more comments
  • H. Sherwin Nov 28, 2012
    I posted a comment but it hasn't shown up. What more can I add to this request? It is not troubleshooting. I just need to know the part number. Please!
  • H. Sherwin Nov 29, 2012
    The response I got from Carrier: "As we do not sell parts directly from the factory, we are unable to provide part lists or manuals. A local dealer would be in the best position to assist you with current part numbers. If you are not familiar with dealers in your area you can locate one on our website." Nowhere on www.carrier.com can I find a dealer locator.
  • H. Sherwin Dec 01, 2012
    I finally found the part number. On the bag: LH 680 014 and L/1 and LF18-094. UPC #: 0 06 62442 18179 4.. I don't know if this is actually a Carrier part--the bag says Factory Authorized Parts and Replacement Components Division + Carrier Corporation. (The bag looks like it had been in a toolbox for two years :-) .
    I forgot to say it cost me $18.25 from the dealer. It is on Amazon for $23.92 if you search for LH 680 014 Carrier flame sensor.
3 Suggested Answers
  • 19 Answers
SOURCE: Carrier 90% *** furnace, fires up, runs until
I have had this problem many times. If changing the flame sensor and cleaning the front of the venturi tube did not help. Also check the ground wire that is attatched to the burner assembly. Also, I have found it necessary at times to replace the wire completely from the flame sensor to the ignition board (circuit board). if you have a multi meter that is capable of reading micro amps, put it in series with the flame sensor and you should see 3-5 micro amps dc. If this is not present, check and make sure that the flame is covering the sensor fully.
Posted on May 17, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMP Furnace problem. Original problem is
Good one! Is the flame getting to the flame sensor within the few seconds? Maybe a good cleaning of the burners or flame tray would help. 1.3 ma is enough for the flame rod to tell the board to stay on. Re-do all the ground connections both at the board and furnace cabinet to be safe. Check the polarity of the power going to the furnace. What are the chances the second board is bad?
Posted on Jan 15, 2010
I have a carrier 58RAV050-12 and my furnace won't turn on. It was working earlier today but it just stopped. Any suggestions as to why?
Check the pilot lt. If its out shutdown your furnace and call a repairman. If the pilot light is on, the flame sensor might have gone out. It's a long silver sensor that sits in the pilot light flame and senses when the flame is present. If it isn't working the furnace will automatically shut down.
Nov 04, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Ignition lockout on carrier furnace. How to get furnace running again
It locks out because their is a problem with the flame ignition after it tries to light several times it locks out. Could be a flame sensor or bad igniter. Could be other reasons but these are the most likely. You can reset it by turning the power of and back on again
Apr 22, 2013 | Heating & Cooling
I AM WORKING ON A CARRIER 90% FURNACE. IT WILL NOT FIRE UP. IT SHOWS A 34 CODE. THE IGNITOR DOES NOT ENERGIZE FROM THE BOARD. NO POWER COMING FROM THE BOARD. I HERE A CLICK AS IF IT IS TRYING BUT NO...
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat.
2. Draft inducer motor starts.
3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes.
4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution: You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. Please see "limits, rollout switches & furnace control boards" further down on this page. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 25, 2010 | Heating & Cooling
Carrier super saver furnace keeps going on and off
Sounds like the flame sensor is dirty or bad. This sits in the burner flame when the burners are running. This usually has a single white wire connected to the back of it.
Jan 03, 2010 | Dayton Gas Furnace Heater
Having problems with Carrier 58RAV furnace. Goes through the motions, but gas never turns on. I think it is a problem with the LPGS. Please advise. Thanks
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Dec 24, 2009 | Carrier Heating & Cooling
Sometimes this can be caused by a dusty control board.
Inspect flame sensor, (located in burner area, opposite side of hot surface ignitor). If the tip of sensor have a white carbon build up on it, it needs to be removed and cleaned, Good luck.
Oct 06, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace keeps turning on and off
Okay, what is going on. is the system lighting or not. If it is just sparking then you need to just the gas value. But if the system lites and then only have a flame for about five sec. then shuts back off, then your flame sensor is dirty. Take a wire brush and clean the flame sensor. The flame sensor is right there with the burns because a flame has to hit it for the gas to stay running. Just take a wire bush and clean it..... let me know
Jan 17, 2009 | Carrier 38CKC042 Air Conditioner
Model number for Carrier furnace with issue for blower 5 minute off delay
I believe that this model number is for an air conditioner evaporator coil. This unit is probably directly attached to your furnace. The Model number for the furnace will be located in the compartment where the flames can be seen. It will be on a sticker or plate that contains lots of other information too like BTU/h, Volts etc...
The number you gave me gives me this info:
Cased air conditioning evaporator coil.
3 Tons
Horizontal application
Jun 27, 2008 | Carrier 38CKC042 Air Conditioner
Open Questions:
Heating & Cooling Logo
182 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
