Question about Proform 400 CT Treadmill - Treadmills
My proform 400 treadmill is making a loud tapping sound when i try to run on it. whats going on
Its not tapping when no one is on but the minute I get on it and start running the tapping sound begins and it get louder if I don't stop and shut it down.
  • 16 Answers
SOURCE: treadmill powers up begins to turn belt then shuts down
Have you tried to calibrate the speed. If not you might want to try it and see if it will help you with your issue.
Posted on Apr 14, 2009
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
  • 40 Answers
SOURCE: My Proform 650v treadmill stop when running after couple of miles
Most likely a bad drive belt. Take the cover off the motor area. If you see black dust near the left side of the motor, replace the drive belt.
Posted on Nov 01, 2009
  • 5 Answers
SOURCE: Treadmill stops when I step on it?
your running belt might b on 2 tight or u dont have enough power going 2 the motor make shure u have a designated power line 2 your machine
Posted on Jan 28, 2010
SOURCE: Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Posted on Apr 18, 2010
I have a ProForm 400 CT. It runs OK, but it just started making a rattling noise.It is intermitant.
Try to lubricate the running belt. Also check the Running belt adjustment.
If you wish to get some details; check the site linked here. Pull up older posts. Choose treadmill articles to know how to Lubricate and adjust the running belt. Almost all the treadmill uses the same procedure
http://electro-medical.blogspot.com/
May 03, 2016 | Proform Exercise & Fitness
Tap tap tap noise when the belt turns on. consistent.
can you determine where the noise is coming from . under the front hood or back. if you can remove the hood and look at the drive belt for fraying . also look at walking belt for fraying. any loose piece will hit something and make noise with every revolution
Apr 16, 2014 | Proform 400 CT Treadmill - Treadmills
What size motor and how loud is the treadmill?
The motor of the Proform Power 1080 is 3.25 horse power. It sounds like a lot but it's not very loud. I can't tell you specifically how loud it is but I run on mine every day and my son sleeps in the room next to me. He has never been woken up from the noise.
Feb 16, 2014 | Proform Power 1080 - Treadmills
Proform 400 GI - Treadmill
go under the HOOD cover the instruction for RUN the software calibration for easy diagnostic , and fix it.
God bless you
Jul 07, 2013 | Proform 400 CT Treadmill - Treadmills
Have proform xt 70. It makes a loud noise when turned on, less noise when walking.
see the video and do it inmediately+ roller bearing Too. God bless you
Jan 07, 2013 | Proform XT 70 Treadmill
Proform performance 400 rattling
what problem do you have error codes, lack LUBE, Elevation motor?
waiting from your comments, i remain sincerely.
However you can RUN the software calibration for diagnostic, troubleshooting and fix it.
God bless you
Oct 07, 2012 | Proform Performance 400 Treadmill Exercise...
Proform 400 ct screen fades out
Dear Sir:I recomend that you read the instruction manual very well in the troubleshooting section.However you can try the RUN the software calibration for diagnose and troubleshooting. Test the fuse inside, or c. breaker, tight any connector that connect the screen very well.Do not use any extension cord, maybe you can use some stabilizer voltage
sincerely. God bless you
May 03, 2012 | Proform 400 CT Treadmill - Treadmills
Proform 400 ct screen fade out
Read the instruction manual section troubleshooting very wellif you do not have the i.manuall get for free download www.fitness.manualsonline.com 2) Tight the connector very well going to the screen. 3) See the c. breaker and reset 4) Test the fuse inside from treadmill 5) See my personal TIPS for help 6) Run the software calibration for diagnose and troubleshooting. 7) Do not use extension cord 8) Use stabilizer voltage 9) Measure the voltage input to the machine must be 115/120 vca maximun tolerance 10% +-10( Try to use independt circuit for the machine.
It started making a loud noise and when I turn it on and step on it it doesn't even run...what can I do?
Hi, did you fix you treadmill's loud noise?
I have a 530X Proform and I'm having the same problem with my.
May 21, 2010 | Exercise & Fitness
Proform 400GI Treadmill making a very loud noise, which is worse when using speeds between 2.7 and 3.1, noise is so loud can't hear tv when turned up to full volume. It makes the noise without anyone...
This definitely sounds like the drive motor. One way to check is to remove the drive belt and run the motor without the walk belt connected. Obviously if you still have the noise it will be a motor issue. If not then it will be one of the 2 rollers. Good Luck! Tim
Nov 04, 2009 | Proform 490GS Treadmill Walking Belt
Proform 400 CT Treadmill - Treadmills Logo
20 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
