Question about Refrigerators
GE Fridge, Compressor not getting power from mother board
Fridge no longer cooling or freezer no longer freezing. Lights OK, both fans OK. Power coming into mother board. No power leaving board to compressor. No power leaving board to defrost either. I believe that it is either in the mother board or in the temp. control panel in front. How can I determine root cause?
  • carl_pickelm Jan 10, 2009
    No storms or anything like that...just real cold. (Typical Michigan weather in December)
  • bob collins
    bob collins May 11, 2010
    What were the waether conditions outside just prior
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
I asked that because in most cases, when it is a problem in a motherboard, it is likely a power surge or lightening. I can also tell you that when it comes to mother boards and component level, likelihood, it isn't transistors or anything unless it smells or looks burned. Most shops would just replace the motherboard and ship it as repaired becaue the cost of the IC isn't worth the possibility of something in another IC on the same board knocking iit out again. Short of plug and play, you have no real way of proving this board good/bad. You might try EBAY with your model number to see if you get lucky. I just got rid of an electronic stove because the control board went bad. New board was $150 with a possibility of it going out in 6 months. As I am not made of money, I now have a gas stove. I you could, please rate this as a fixya as I am just being honest and saving you time and aggrivation. Good luck
Posted on Jan 10, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
GE refrigerator profile arctica Not cooling frige or freezer PTS25LBMARBB
well if the compressor dont have power so how could it work or cool?
Jan 16, 2008 | Refrigerators
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
GSS25UFPBBB refrigerator not cooling properly
Defrost it again remove the back freezer wall panel. At the bottom of the coils is the defrost heater. Replace it and problem solved.
Mar 16, 2012 | GE Refrigerators
Coils freeze up, replaced thermostat, defrost unit, mother board, only marginally works when set on 2-3
It is normal for the coils to frost evenly all over but if it's not defrosted it will build up preventing proper cooling. After replacing your defrost components make sure the frost is being melted. The motherboard determines when to defrost based you your use of the freezer/fridge. It should defrost from once a day to once every two or three days.
Is the fan in the freezer running? It won't cool right without it. It should run when the compressor runs.
Are the coils frosting evenly? Uneven frost means it is low on freon and requires a tech to repair.
Is the fan underneath the fridge near the compressor running when the compressor runs. If not It won't cool properly.
Does the compressor ever cut off as it should when it reaches the selected temp.
Jan 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator stopped cooling, but I still have power and lights, however, my digital cooling settings are no longer lit. Is it possible my board is bad and how do I go about fixing this problem, or can...
check back side of your fridge touch the motor compressor running or not if not running check the electronics board and make voltage check from electronics board to motor compressor. if the compressor running touch the one side of copper tube if have hot one side. if have hot your freon ok check the cooling fan inside the freezer side ok good lock
Jan 01, 2010 | Refrigerators
GE SXS Fridge/Freezer
if the fan in the freezer compartment is not running theres a problem.
verify power to the fan motor, if present replace fan motor.
if not hopefully theres a wiring schematic/diagram so you could trace that circuit back to the control board and verify whether thats bad or not..
WR55X10942 - BOARD ASM MAIN CONTROL
generally though if the fan by the compressor is running the fan in the freezer should also be spinning and have power..
by the way, it states in the parts listing that it is a dc motor
WR60X10074 - Motor DC Evaporator Fan
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | GE GSS20IEP Side by Side Refrigerator
Fridge freezer not working after power cut
if its a ge i would say itsyour main board not compressor boards about 200
Mar 19, 2009 | Refrigerators
GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Jul 24, 2008 | Refrigerators
Side by side cooling problems
replacing evaporator motor and mother board
Apr 02, 2008 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
666 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
