Question about Gateway Solo 5300 Notebook
Need instructions on how to replace the fan on gateway solo 5300
I need to repalce the fan on my 5300. Instructions would be great.
  • shopper852 Jan 13, 2009
    i need specific instructions on cracking the case, removing the fan and replacing it, on this model notebook. i know the fan is dead.
  • Gateway Master
  • 19,396 Answers
On other laptops, you need just to access to a door at the bottom to replace the fan.
On a gateway, you remove keyboard, aking case not to break the mosepad and keyboard ribbon cable.
To remove Keyboard see SOLO 5300 5350 REMOVE REPLACE KEYBOARD.pdf
Then undo screws at the bottom, then pull up upper casing, then remove fan cover plate, unscrew fan and replace it.
You find more manuals here.
Posted on Jan 14, 2009
    Genius:
  • 1,239 Answers
Hi
Opening Underside Panel
1) Disconnect all power souces to the notebook. (Battery(s) & AC Power)
2) Close the notebook if you havent so, then flip it over so that the bottom is facing you,
3) Using the screwdriver, remove the 11 screws enclosed by a red box as above.
4) There is a little imprint/dent that allows you to slip your fingernails under to lift the panel up. Lift the panel up gently (at an angle), it should come off easily.
Once the panel is off, this is what you'll see:
Posted on Jan 13, 2009
  • 1 more comment
  • ABHISHEK.C
    ABHISHEK.C Jan 13, 2009
    ANY DOUBT?
  • ABHISHEK.C
    1. Take your 8 Tiger Elastic Fixations and
      stick them into the holes of the two fans. Stick them in the holes on
      the side where the air gets blown out. This usually is the side where
      the label of the fan is attached to. The output of this operation
      should look like below.
    2. Now
      press the fans with the Tiger Elastic Fixation on the aluminum heat
      sink. You must place the two fans close to each other and align them
      with the case of the harddrive bay. If you close the case of your MDD
      the fans should inherit the place of the second harddrive. You should
      ensure that the two fans don't touch each other because that could
      cause vibrations what again causes a disturbing sound.
    3. If the fans are in the right place connect the the wires of the fan to the Y-molex cable.
    4. Connect the end of the Y-molex cable to the male connector of the 5.25" -> molex adapter
    5. Connect the 5.25" connector to the second 5.25" connector from the harddrive cabling.
    6. Put the spiral bound arount the cables.
    7. Put the cables in such a way so that the don't get damaged if you close the case.
    8. Close the door of your MDD. If you placed your fans correctly there should be no resistance.
    9. Start
      your MDD and check if the fans are running properly by opening the door
      again. You will notice that (even) if the door is open the CPU fan
      won't accelerate. It definitely would if you hadn't the two fans placed
      on the heatsink.
    You should check that there is no metal
    wire that touches the metal case of your MDD. Unless you create the
    wires for this modification yourself this is not really a problem since
    the bought cables are all properly isolated
  • ABHISHEK.C
    MORE REFERAENCEhttp://images.google.com/imgres?imgurl=h...
  • 199 Answers
The CPU heatsink and fan combo is right under the keyboard. Remove the keyboard and status board. A number of screws must be removed to enable removal of the heatsink/fan combo/assembly plus the fan's cable.
Hope this helps.
    Brigadier General:
  • 5,158 Answers
This is not an exact match for your needs but you may be able to find helpful hints and or similiar laptop dissasmebly instructions here http://repair4laptop.org/disassembly_gateway.html
you can download gateway service manuals here as well to give you a better understanding of taking it apart
http://www.eserviceinfo.com/equipment_mfg/Gateway_43.html
these should provide you with a fair bit of knowledge to do the repair
Robert
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my understanding, a Gateway Solo 5300 is nearly identical in terms of physical/mechanical construction to a 9300. Assembly and dis-assembly for a 9300 maybe found here with detailed step by step procedures and illustrations.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
    Master:
  • 416 Answers
Follow this link
Hope that helps
Good Luck
http://www.fonerbooks.com/lap_fan.htm
  • 124 Answers
Contact toshiba for opening the case so you know exactly what screws need removed also try checking youtube for some instruction videos
    Sergeant:
    Scholar:
  • 199 Answers
The guts of a laptop are crammed into such a small, cramped space, that the cooling fan is absolutely critical. A replacement laptop fan and heat pipe should cost well under $50, you may even get by with a generic fan replacement for a few bucks, but the job is fairly involved and differs from manufacturer to manufacturer. I don't get excited about noisy laptop fans, I had one in my Toshiba Satellite that got noisy within a year of my buying it and continued noisy for the next four years without failing. On the other hand, you don't want to wait until you get heat damage to replace the fan. If the fan gets increasingly noisy over time or starts noisy (and slow) then quiets down as it picks up speed, I'd replace it at the first opportunity. Assuming you've owned the notebook for a while, you should be familiar with how long the fan usually takes to come on and how long it runs. If the fan never comes on, unless you're working in a freezer, it's probably dead. I just did a page on troubleshooting laptop CPU overheating problems and inspecting the laptop fan for linting or failure.
just click the link below for more details
http://www.daileyint.com/hmdpc/repair.htm
Posted on Jan 10, 2009
    Master:
  • 505 Answers
What brand is the fan please
Looking for the manual for Dell gateway solo 5300 laptop. thank you
Hi Julmurrieta you can check this manual for Gateway Solo 5300. Please click the word manual to see the link.
Apr 14, 2011 | Computers & Internet
Wireless switch on model solo 5300
Hi. Not enough information. Do you want a switch? Do you need to FIND a switch? Is it a Gateway notebook?
The specifications for the Gateway Solo 5300 do not indicate a wireless system as part of the original unit.
See:
http://support.gateway.com/s/manlib/Notebooks/Solo5300/8508144/8508144.htm
Most units with PC100 memory (like this one) did not come with wireless. You will likely need a wireless PCMCIA card.
Mar 21, 2010 | Gateway Solo 5300 Notebook
My notebook loads to the testing window and wont go any farther than that
we can fix it...
vist my site
http://www.sureshayyar.110mb.com/
go to my FromatDisk page and follow the instructions...
u will get back ur notebook in factory fit condition
kindly leave a feeback and rating on how u did...it will help me improve my suggestions in future
Jan 16, 2010 | Gateway Solo 5300 Notebook
Don't remember password on bios of a gateway solo
Simplest is to remove the battery for a while so the password is lost.
See the TechRepublic article at
http://articles.techrepublic.com.com/5100-10878_11-1032878.html
Nov 19, 2009 | Gateway Solo 5300 Notebook
How do I replace the hard drive on a gateway solo 1450 laptop? I need to get the black plastic piece off so I can put it on the new drive
Hard drive replacement instructions (from the Gateway site) for your notebook are here.
http://support.gateway.com/s/Manuals/Mobile/8508627/8508627o.htm#1024735
The entire User Guide is here:
http://support.gateway.com/s/Manuals/Mobile/8508627/index.htm
Good Luck
Oct 21, 2009 | Gateway Solo 1450 Notebook
Gateway 5300 solo fan control and heat monitering
I believe gateway locks their heat limits. But in order to change it you should be able to inside of the BIOS/CMOS/SETUP when first starting the machine.
May 27, 2009 | Gateway Solo 5300 Notebook
Password changed all by itself
You can change the password by following this link and following ALL instructions. http://www.petri.co.il/change_user_password_from_the_command_prompt.htm
Mar 15, 2009 | Gateway Solo 5300 Notebook
Gateway solo 5300
Look at these sites:
This is a good "how to" with pictures (although it doesn't show your particular model):
http://www.laptoprepair101.com/laptop/category/lcd-screen-repair/
This shows how to remove the keyboard for your model:
http://support.gateway.com/s/Mobile/Solo_Series/p5350/8508369/8508369.htm
http://support.gateway.com/s/Mobile/Solo_Series/P5300/P5300nv.shtml
http://support.gateway.com/s/Mobile/manuals/8508399/8508399.htm
Manual for your model:
http://www.supportspot.net/gateway5300.pdf
Oct 21, 2008 | Gateway Solo 5300 Notebook
Computers & Internet Logo
75 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
