SOURCE: How can i receive fax on my printer
Your printer should have software to install for the fax. Then go to control panel and click the fax machine, check your connectivity settings and make sure the phones numbers are correct for out-going and the in-coming settings.
If you do not see the fax in printers then the fax part of the printer has not been installed, then install hardware, then software and use the install wizard if you have one. This helps too.
SOURCE: i need to dial zero before i get dial tone cannon MX700 cant send fax ???
You can set dial preferences in fax options using the 0 for the switchboard.
SOURCE: I have a Canon MultiPass 730 multi-function
o.k. I believe I can help you.
Open your file of interest to fax in word, adobe, or text software.
Click file print.
now in your print dialog box make sure your canon MP730fax is selected.
Also, make sure all is bubble clicked for your page range.
click o.k. and a send fax dialog box should appear.
enter recipients info or chose from address book.
Now click send.
It should now fax all pages in that document to the fax you have selected.
You can only send to one recipient at a time with this feature but it should allow you to send all pages in your document.
hope this helps be kind and leave me a testimonial it helps me too.
than ks GOOD LUCK!
SOURCE: i can send a fax
Hello there, the Canon Pixma MX420 is a great unit. All you have to do is get the network trouble shooting and settings. Here is a link to help you get All the manuals available for this unit. simply follow the network setup troubleshooting tips and you would be able to setup the fax system.
Hope this solution has been helpful?
Thank you for visiting FixYa.
