Question about Radio Flyer Liberty The Spring Horse By
Spring Horse I've lost the assembly instructions for my kid's spring horse. Does anyone have an assembly diagram or instruction sheet?
You can go to the Radio Flyer website and download the assembly instructions.
Posted on Apr 18, 2009
Center of the stand hits floor before the rubber pads
Refer this issue to Global directly. From your description, something is not right with the assembly and there may be some additional hardware that is missing. Also, the instability could pose a hazard to a small child.
Dec 20, 2013 | Global 28-Inch Wonder Horse Spring Rocking...
Toy
replacement springs for some hobby horses are available at local hardware stores. Look for a select a spring assortment, or a store that can order from Servalite. They stock them in their catalog. Otherwise a handyman might be able to shorten the overstretched springs to raise the front legs.
Jun 15, 2013 | Tek Nek Toys Lucky Deluxe Spring Horse
Are rocking horses safe to buy as toys?
Rocking horses have a bit of a reputation for being dangerous because of a few accidents involving the reins around the rocking horse. You do really have to be careful not to leave young children unattended.
And you can shorten the reins on the horse so that there's no danger of strangulation.
when kids go too fast on a rocking horse they can cause it to tip over but this is true of nearly all motion type toys.
i still think the rocking horse is a classic but you should be careful to supervise kids who are using it.
Jan 14, 2013 | Toys
Lost instructions for pirate island imaginarium
Instructions for Imaginarium Pirate Island
http://www.docstoc.com/docs/document-preview.aspx?doc_id=135875316
Feb 18, 2012 | Toys
I have a Stanley SharpShooter PHT150 that's jammed. I would like a diagram/instruction sheet showing how to fix this problem. Thanks.
Here is a copy of the instruction manual for your stapler.
1. Press end clip in, then up.
2. Pull out spring assembly.
3. Load staples into channel.
4. Reinsert spring assembly and
snap end clip into place.
EASILY DISASSEMBLED
FOR CLEANING:
1. Squeeze stapling end of hammer
tacker together, taking care to
avoid sharp staple.
2. Remove locking pin.
3. Press end clip in, then up.
4. Pull out spring assembly.
5. Remove staple channel.
6.Clear and reassemble
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 16, 2011 | Stanley Tools Hammer Staple/Tacker -...
Cratftsman Lawnmower; 16.5 horse; 42 inch deck, need assistance replacing armbrake and tension spring #58 on sears schematic; MOwer model number is 917271120-- particularly, where does this spring attach?...
Judging by the diagram the spring mounts under the armbrake, the Bolt (#52) goes through the circular spring. One end of the spring goes into one of the holes near the bolt on the armbrake and the other ( after providing tension by turning the spring ) must attach to a non moving part on the deck to be able to provide the required tension Look for a small turned up piece of metal with a notch in it on the housing.
Hope this helps
May 18, 2011 | Garden
Diagram for right rear brake assembly for a 1993 chrylser lebaron
it's a standard leading trailing bendix brake system, small shoe to the front, larger shoe to the rear. The spring are ease. THE springs that look the same go behind the shoes, the biggest spring goes at the top of the brake assembly, and the spring thats medium goes on the bottem. Don't forget the horse shoe clip to the e-brake cable. The adjustment peice goes near the top. Adjust it all the way and spin the drum while you use the mopar adjustment tool to set the e-brake adjust ment. you should get 1/2 to one full rotation before the drum drum stops spinning. don't forget to gravitey bleed your brake (open the rear bleed screws at the same time, then the front).
Oct 16, 2010 | Chrysler LeBaron Cars & Trucks
Radio Flyer Liberty The Spring Horse By Logo
791 people viewed this question
Top Radio Flyer Toys Experts
Tom Chichester
erex 01
erex 01
Are you a Radio Flyer Toy Expert? Answer questions, earn points and help others
