Question about Home Security
1F78 emerson white rodgers thermostat stuck at 77 degrees of heat
Only provides 77 degrees of heat
liteswink
  • 99 Answers
SOURCE: need the wiring manual for a White Rodger
Please call the hometechline at 18002842925 to ask for a copy to be send to you, be ready with a valid emial address.
Posted on Jun 26, 2010
liteswink
  • 99 Answers
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
Posted on Oct 20, 2009
liteswink
  • 99 Answers
SOURCE: I have a White Rodgers thermostat series 1F78-151
- Check the wires on the terminals make sure that they are not loose
- Reset the unit by press time, up and down buttons make sure the systems is in on position.
- Set the system to cool then and lower the setpoint below room temperature. There may be up to five minute delay before the thermostat clicks in cooling. If the thermostat click this means its not a thermostat you have a problem with your cooling equipment call your installer. If the thermostat did not click the unit should be replaced.
Posted on May 26, 2010
liteswink
  • 99 Answers
SOURCE: MY White rofers 1f78 is stuck
Reset operation the system must be at cool position then press UP, DOWN and TIME buttons simultaneously. If the reset did not work call the hometechline 18002842925.
Link: MANUAL
Posted on Jul 20, 2010
reddawgesq
  • 134 Answers
SOURCE: I have a problem with a White rodgers 1C20-101
The Operating Manuals for many White-Rodgers thermostats can be found in PDF form HERE, however they are not indexed by model number so you will have to download each file in turn until you find the one you want. All of the file names beginning with "0037-" seem to be W-R products.*Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Posted on Feb 03, 2011
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
My White Rodgers 1F78 programmable thermostat shows a constant room temperature of 83-84 in the afternoon, but I set it at 77 throughout the whole day and night. Should I get a new one?
It sounds like the temp sensor is defective in the T-stat. I would replace it, get the newer programmable ones, they are very reliable and very cheap to buy online.
Sep 21, 2016 | WHITE-RODGERS DIV 1F78-151 White 70 Series...
My 1f78-151 is stuck! the up and down won't move and it says the house is at 69 but really is at 52
Mary, are you sure the thermostat is in fact getting the furnace to start...???? It sounds like the furnace is NOT starting in heat mode.
Nov 29, 2015 | Sears Parts Direct White-Rodgers 1F78-151...
The white-rodgers 1f78-144 does not work properly
Is it in the heat or cooling mode? Might try a new set of batteries.
Jan 22, 2014 | WHITE-RODGERS DIV 1f78-144 Digital...
I have a White Rodgers thermostat series 1F78-151 that is displaying we at the top?
Hi. This is Aaron Moratalla from White Rodgers. For 1F78-151, "WE" means Wednesday. If left side temperature is stuck at 67F and there's no Hot air coming out then try ressting your thermostat by:
1. set system to Heat mode
2. press simultaneously the Up, Down arrows and Time button for 2sec.
3. the screen should blank out momentarily then show 62F in the right side.
4. set a higher temperature in the right side than the left side of LCD to have a call for heat.
If you are still having problems please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
How to wire white rodgers thermostat 1f78
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from White- Rodger's. First thing you need to do is to verify the function of each of the wires then cross that over to the terminal function of our thermostat. If have difficulty doing this contact us directly at 18002842925.
Jul 30, 2012 | White Rodgers Home Security
Link: MANUAL
Jul 20, 2010 | White Rodgers White-Rodgers 1F85RF-275...
1F78 thermostat change from F to C
yes to cut the wire named W904 at the middle.
Sep 19, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Home Security Logo
137 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
