Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
S2046 Scotts B & S engine starts but won't keep running. suspect fuel pump, but when I take off the hose, pump is pumping fuel into carb.
  • pb33 Dec 06, 2012
    changed out fuel pump...not the problem.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Briggs & Str... Expert
  • 133 Answers
Its the carb acid dip and rebuild
Posted on Mar 12, 2013
3 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: Can you assist with a John Deere lawn tractor? I
Leo, try removing the fuel bowl first and checking to see if the needle valve and float are working correctly.
Typically, whenever the fuel system has been "shellaced", the small port that lets fuel flow from the bowl into the carb, gets clogged. You can check this by removing the center nut on the bowl to drop it down. (turn off the fuel valve 1st) and be careful not to let the needle valve and spring retainer fall off the float.
Once you've done that, you can spray some Carb & Injector cleaner thru this port and use a small pipe cleaner to make sure the hole isn't clogged. Also, check the float to see if it's got any gas in it. If it does, you'll need to replace the float, as it shouldn't have anything but air in it, hence the term "float".
You should be able to get the carb working fine after doing the above, since you can get the engine running by spraying cleaner (starting fluid?) into the carb.
Here's a link to the B&S site where you can get info on your particular engine by using the model number stamped on the engine itself.
http://www.briggsandstratton.com/maint_repair/manual_and_more/
Hope you find this Very Helpful and best regards!
Posted on Aug 29, 2009
bgduff366
  • 14 Answers
SOURCE: craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Head gasket is blowed .Its building pressure in the crankcase seen it twice. Remove the head and check for a blowed out spot between piston and the valve side
Posted on Jul 29, 2012
My 4514 Honda has a snow blower for the winter . It keeps stalling and the fuel pump never shuts off so I guess isn't pressurizing . I pulled the fuel line at the carb & it is pumping gas ....
sounds as if there is sticky gum in the carb that is keeping the float from seating unless it is hot enough to unstick. Take the carb bowl off and examine it for gum (real old gasoline will do that.
Feb 02, 2015 | Honda Cars & Trucks
Lawn mower won't run. Cannot start it.
sometimes the primer bulb gets cracked and wont properly pump fuel into the carb. replacement of the bulb should fix the problem.
Jun 15, 2013 | Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
I have a Scotts lawn mower model # 229630X8A I am having trouble getting fuel to the carb. I have cleaned the carb. and the problem is still happening/ What part could it be?
your fuel pump bolted on left side of engine hoses are contected to engine and carb make sure they are secured and check your fuel filter maybe plugged or a pinched hose from gas tank look around
Joe
Sep 30, 2012 | Garden
Fuel problem with John Deere 23hp engine
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
May 15, 2012 | Briggs & Stratton Briggs Stratton...
Engine surges won't run with out choke and then it stalls
If the engine surges and won't run without choke it is starving for fuel. Best place to start is the fuel filter. After the fuel filter, pull the fuel line off of the carburetor and place a container under the fuel line to catch the fuel. Crank the engine over and watch for the amount of fuel being pumped through the line. There should be a good stream of fuel with each pulse from the pump. Chances are the pump diaphragm is getting weak and it cannot keep enough fuel in the carb to run proper. Check those items and let me know if it helps, Daniel.
Sep 29, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
My 96 yukon wil not start. Sounds like it will crank over but won't. It is not the fuel. I changed the ignition coil still won't start.
try spraying some carb cleaner into a vaccum hose and see if it will run. If so then you have ignition but no fuel delivery. If not then you have an ignition problem. make sure you hear the fuel pump hum when you turn the key to the run position. It should run for +/- 5 seconds then shut off. remove gas cap and listen for fuel pump operation through the fill hole. If you can hear the pump then you have a fuel injection issue. If the engine starts and runs for a few seconds then shuts off then you can suspect the crank or cam position sensor. The fuel pump runs through the oil pressure switch which could also be an issue.
Are you able to start the truck with application of the gas pedal?
Sep 22, 2011 | 1996 GMC Yukon
I have a 1996 Chevy Blazer 6 cylinder 4.3 Vortex engine. The check engine light has been on for a few weeks but it was running just fine. Until all of a sudden it wouldn't start last night. I had...
My first thought would be: If you repaired an emissions hose, take the car back to Auto Zone (or another parts supplier) and let them tell you what code comes up now. You eliminated one problem, now you have to find another.
I wouldn't do a fuel pump without more information.
Gary
Jul 20, 2011 | 1998 Chevrolet Blazer
Have to use starter fluid to start my car
Starving for fuel. Start by making sure the fuel pump is running. Turn the ignition on without starting the car and listen for the pump. It should run for a few seconds and then shut off if you don't start the engine. If you hear nothing, check the fuse. If the fuse is good then it can be a defective fuel pump relay, pump itself. If you hear the pump run and then shut off, suspect a clogged fuel filter, defective fuel pressure regulator, or an extremely weak fuel pump that is running but pumping no fuel.
Feb 10, 2009 | 1989 Dodge Shadow
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
310 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
