Question about 1996 Pickup Short Bed Xe Egr Valve Vacuum Switch
The code po108 and po110 what do they meani have a 1996 nissan xe pickup has a jumping problem have changedplugs and wires distribulator fuel filters and put seafoam in tank but still have problem can
When put on machine can out with codes po110 and po180 what do i do now
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 74 Answers
P0110 is for air intake temperature sensor, The intake air temperature (IAT) sensor is built into mass air flow sensor or in some vehicles mounted to the air filter duct housing. The sensor detects intake air temperature and transmits a signal to the Engine Control Module (ECM). The temperature sensing unit uses a thermistor which is sensitive to the change in temperature. Electrical resistance of the thermistor decreases in response to the temperature rise. The IAT sensor signal is used as an input for various systems in the vehicle.Possible causes:
- Faulty Intake Air Temperature (IAT) sensor
- Dirty air filter
- Intake Air Temperature (IAT) sensor harness is open or shorted
- Intake Air Temperature (IAT) sensor circuit poor electrical connection
P0180 means: The fuel tank temperature sensor is used to detect the fuel temperature inside the fuel tank. The sensor modifies a voltage signal from the ECM. The modified signal returns to the ECM as the fuel temperature input. The sensor uses a thermistor which is sensitive to the change in temperature. The electrical resistance of the thermistor decreases as temperature increases. Possible causes:
- Faulty Engine Fuel Temperature Sensor
- Engine Fuel Temperature Sensor harness is open or shorted
- Engine Fuel Temperature Sensor circuit poor electrical connection
Resolving P0180 could be a significant procedure if there is no fuel pump access panel. IF there is no panel or means to remove the fuel pump assembly from the tank, you will need to drop the fuel tank to get the sensor out in order to replace it.
Posted on Feb 06, 2014
How to drain fuel tank on 1995 Nissan pickup
you need to drop and remove tank away from vechicle where you can drain it completely.
Mar 28, 2013 | 1995 Nissan Pickup
How do i replace a thermostat on a 96 nissan xe pickup?
It is located at the enine end of the lower radiator hose inside the metal piece atttached to the engine. the metal piece has 3 bolts to take off that attach it to the engine. I took off the fan and fan shroud for easy access. this is fora 95 xe 4 cylinder.
Dec 11, 2010 | 1996 Nissan Pickup
Location of voltage regulator on 1996 Nissan XE pickup
The voltage regulator is built into the alternator. It's that way with most cars now.
Nov 02, 2010 | 1996 Nissan Pickup
Nissan sentra fuel problem. Put new filter and fuel pump but no gas getting to filter to get to pump. Gas line problem from tank?
I believe this is a manual fuel pump and you may have lost the prime, no fuel in hose to tank. If the hose from rear frame to tank has a break or hole, it will **** air and not fuel from tank. If this is not the case, possible clogged fuel hose, tubing, or pickup tube in tank assuming you have turned the engine over serveral times and there is enough fuel in tank. Some tanks do not pickup from very bottom because of water laying in bottom of tank from condensation.
Dec 12, 2009 | 1984 Nissan Sentra XE
19966 nissan pickup sputters at a stop light,but
possibly a spark plug wire loose or plugs need replacing?
Feb 27, 2009 | 1994 Chevrolet S-10 Blazer
MAP sensor location
look to the left of the air filter for a module with 1 vaccuum hose and three wires. It may be labled as a boost sensor. I had a 97 XE and that's where mine is
Jul 05, 2008 | 1995 Nissan Pickup
1996 Pickup Short Bed Xe Egr Valve Vacuum Switch Logo
167 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jim Y
Jim Y
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
