Control lock
Sears front loading machine has the control lock light on, cannot open door. Does not reset even after unplugging machine
  • Washing Mach... Master
  • 2,651 Answers
Look closely at the control panel there is a button marked"control lock hold for 3 secs." probably a small pic of lock on it as well, simply hold for 3 secs to release it,
Posted on Jan 10, 2009
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Jan 15, 2013 | Electrolux EIED55HIW Electric Front Load...
Control lock light
control lock light ? have you got any blockages or dirty filters you may have to clean them.
Jul 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The control lock light is on. The machine will not work. I tried unplugging it for 1/2 hour hoping it would reset. Whirlpool Duet Washing machine
The door will have to pried open and door switch will have to be tested or replaced. You can use a multi-meter or ohmmeter.
Worst possible cause is faulty eprom or control board but usually is faulty switch or door sensor.
Jun 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL code message
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replace the door lock mechanism asap. this will fix the issue.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
The comment posted 14 may 2009 it what helped me. DO NOT PRY OPEN the door. Find the release cord inside the soap dispenser,,,you may have to remove the 4 screws and lift it from the washer like i did. I had to lean into the door and pull the cord to release the lock. It was not a system error. The washer was over loaded and although the door was closed and locked...the load pushed the door enough to indicate that it was open and would not wash. After opening the door, rearranging the load and removing some, the door closed and latched locked and was able to continue with the wash. DO NOT PRY OPEN,,,use the cord release first,,,this worked for me.
May 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
The control locked light is on and can't start the machine
Power shd be on, try to hold down 'end of cycle' button for 3 seconds, try door after a minute or after hearing a click. IF NOT:
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about 1/4 inch or until a click is heard.
6. The door may now be opened.
Apr 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Load Washer 417.44152400 lights up, no activity
Find the button on your panel with a 'key' symbol. Press & hold this down till the lock light goes off. Or
Hold down the 'options' & 'select' buttons together till the lock light goes off. Or
Press and hold down "end of cycle"
Pl. rate & tell me what did it - it is important.
May 23, 2008 | Kenmore 44102 Front Load Washer
Kenmore HE4t Washer stuck in "controls locked" mode
you need a new cpu you can unlock door by removing bottom panel reaching up to the door lock and pulling a little ring on the bottom will manualy unlock the door
Nov 08, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
