Question about Panasonic SA-XR25 Receiver
No sound on DVD mode
When we play a dvd - no sound comes out. If we put it on CD mode - we get the music but no audio. We have had problems from day 1 with this. How do I fix this problem. I am NOT an expert and will need very specific step by step instructions.
  • Anonymous Nov 16, 2008
    I just got a SA-XR25. It seems to be stuck on DolbyPLII. I can't switch it to any other surround mode.
  • Anonymous May 13, 2009
    NO SOUND ON DVD MODE
Make sure when you select DVD mode that it's not set to "6 ch". (The display will say "DVD 6CH") If you are in the 6CH mode, Use the remote to switch out of this mode by hitting the DVD button again. Hope this helps.
Posted on Jun 29, 2007
SOURCE:
Dvd audio
remove it from device manager and see whethrer there are any resource conflicts
May 24, 2010 | Creative Labs Sound Blaster Live! 5.1...
When i insert the cd/dvd in dvd drive and copy some thing from the cd/dvd and instantly playing the music the sound of music is coming discontinously why
#1, try to do nothing else while recording. Second, when the computer start up, and the start up sounds plays, does it sound bad? If it does, you are having problems with windows.
Sep 03, 2009 | Computers & Internet
When i play music cd all speakers work but when put a dvd on only the 2 front ones and centre speaker goes? Tried all settings. Y are my 2 surround sound speakers not working? I have a pioneer vsx-816...
What is happening is the the pioneer is set up so that you can choose how you listen to your DVDs. So first you must see how your DVD is connected via the audio. I am fairly sure that the Default on the Pioneer is to play it through the standard stereo if all you have plugged in is the left and right audio plugs. If you buy an optical cable or a plug in the Digital Coax out put to the pioneer receiver, then the pioneer will decode the sound and out put true surround sound. Some DVD players don't have a digital out put, but these are the cheapest ones out there. If yours doesn't have a digital out put, then you need to get one that does. They can be purchased for as little as 39.00.
Okay lets assume you bought a DVD player with Digital out put for audio and you have it connected to the receiver. Now, you have to change the mode on your pioneer to let it know that your audio is coming in DIgital when you select the DVD. (Though this may already be the case and you won't have to do anything once you connect it.)
Dec 08, 2008 | Pioneer Televison & Video
No Sound when I play a DVD, but I do have sound when I play a Music CD
Open your sound controls to make sure nothing is muted or set on low volume.
If that's not the case, open your audio drivers program and check to see if nothing is muted.
Oct 22, 2008 | Computers & Internet
No picture, only sounds when playing DVD
The issue might be that you could be missing some codes to play the dvds.
First i want to uninstall all the codecs from the control panel - add/remove programs.
Then download the latest vesion of klite codec pack with the player.
The link is :
http://ftp.freenet.de/pub/filepilot/windows/multimedia/video/k-lite_codec_pack/klcodec390f.exe
Install this by selecting "lots of stuff" with the player.
Then play your DVD, it will work fine.
Good Luck.
Live, Love, Laugh.
May 08, 2008 | Haier PDVD10 Portable DVD Player
Dvd getting picture but no sound
can you play a music cd? if not, your probably missing the audio cable that hooks between the player and the motherboard or soundcard ( if a separate card is installed )
Feb 23, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Audio problem by DVD Play
You need to check to see if the dvd drive is set to digital playback because
it is probably trying to find your on board AC97 - 5.1 digital output. With
a music CD it doesn't have to be connected digitially because it uses analog
for stereo playback but most DVD's - if a movie - are set to playback in
digital. Open 'My Computer', right click on your DVD drive, select
properties, select hardware, highlight your DVD drive, click on properties,
then properties again, check- Enable digital CD audio for this CD-ROM
device.
Jan 26, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Problem
for audio to be able to play in an older cd play that does not support mp3 formatted music you need a program that will put them into audio format I use apples I-tunes to do that and for you dvd burn to be able to work on dvd players it has to be in the right coding and for that you can search for just about any dvd burning program and it will do it automaticly. hope this helps you out
Jan 23, 2008 | Computers & Internet
Are you sure your player has got the right codecs to play both audio and video of the DVD you have burnt?
PS: Try installing the Ace Mega Codecs Pack just to make sure you have all the codecs. (Remember though that this software will install all the required codecs as well as the unneeded ones...the ones maybe required in the future probably)
Oct 18, 2007 | EPoX EP-8NPA7I Motherboard
Random no audio
I have had this happen with this particular brand frequently. I have it plugged in to a power "strip" or surge protector. I find that if I turn the strip off then on again, it resets and fixes the problem.
Feb 18, 2007 | Cyberhome CH-DVD 300 DVD Player
Panasonic SA-XR25 Receiver Logo
159 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
